Just a curiosity
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Just a curiosity
    Posted: 08 Nov 2025 at 7:22am
Have been taking Celebrex or the generic Celecoxib as is about the only NSAID that still has a function for me, does have a Tylenol med component to it.
We are on Well water so tend to get the typical mung ring around a week after cleaning of spare baths or a few days in Wife’s bathroom stool. HOWEVER the toilet I tend to use stays relatively Mung free. So to extend the visibility experiment swapped to using a spare bath stool and it then cleared up without cleaning.
Beginning to wonder as to that fear of Tylenol if can thru urine clean a toilet ring away. My diet had not changed other than increased use of Celebrex due to age ache increases.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2025 at 8:47am
  I would try to find something other then Tylenol, it is literally poison, depending on your body weight six pills  at once is lethal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2025 at 11:04am
Yet ivermectin is also a poison as is Blood Thinning Meds.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 49 minutes ago at 3:34pm
Well water without softening it as well as city water will leave behind a ring on porcelain as water evaporates and leaves a lime scale behind. It's not the meds but something else . guess you could get some litmus paper and test the pH of both bowl water and of the discharge you are adding to it and find part of answer .
 I just used Lime Away on bowl in my bathroom to remove part of the ring left behind after 6 months or so as regular bowl cleaners do not attach the ring but will clean standing water area .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 59 minutes ago at 5:24pm
Other bowls retain that ring until I use regularly, different bowl same results. Do have softened water.
