John Deere strike
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2021 at 6:08pm
When I owned my tire shop I had a good customer go to work at the JD plant in Ankeny. He grew up on a farm and worked on 1 for several years before wanting a job inside out of the rain and snow. He started and went to work building combines, etc. He almost quit several times. He couldn't stand the slow pace of working there. He said those guys could turn out 3 times the number of combines if they'd get off their butts and actually do some work. I am not running down unions. Just stating what a hard working farm kid told me. One of several reasons their stuff is so over priced.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2021 at 6:41pm
Similar story from my dad and several others I knew who had worked at FMC
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2021 at 6:59pm
You guys would not believe the HORROR stories from a former "FOREMAN" of a non-union project company that had to basically "BEND OVER" and smile Cry .
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2021 at 7:57pm
In 1978, there was Farmall in Rock Island, IH in East Moline... and three other Deere facilities in Moline, East Moline, and Silvis. In Bettendorf, there was JI Case. In north Davenport, JI CASE.  All of these plants were within a 7 mile radius.
Also within same radius, was over 400 small manufacturers, and 1000 supplier facilities (bearing companies, hydraulic, electrical, and mechanical suppliers, etc)... and a workforce of over 40,000 union employees.
By 1984, all those manufacturing facilities were totally shut down, and over half the small businesses were gone.
I walked through the Rock Island Farmall plant in 1990...  the old brick walls were painted white, and every 20 feet, were exquisite paintings of each red tractor they'd manufactured, along with signatures of the names of the workers who built those machines.
None of those walls still stand.  The huge IH facility on the upper end of Ben Butterworth Parkway was emptied and flattened, now there's a hotel out there.
If they choose to be foolish, there's nothing anyone else can do about it, but most of my school classmates whose parents were proud to sit out on the line, wound up moving away, hoping to find opportunity elsewhere.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2021 at 8:45pm
The reason it’s so overpriced is because they charge what the market will bear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 5:19am
Actual labor costs are a fraction of overall expenses in manufacturing, worked Union and Non, benefits were bargained for to keep skills at the Union facilities, non union shops tended to be close to slave labor markets where the politically correct butt kissers got raises behind closed doors and those that kept the machines moving took it on the chin moving on after honing skills, 99% of those facilities closed in under ten years due to quality issues.
There is far more to machinery costs than Union labor, CEOs earning 400 times the average wage, followed by COO, CFO, boards of directors getting stock shares in the millions of dollars face value for their expertise in upper managerial wisdom. Then the point much of the production is from overseas being assembled here to sate the Fed as to ‘manufacturing’ here to bury profits into offshore funds.
Lots more to it than ‘Union is bad’ thinking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 4:43pm
In my previous "horror story" reply, there's a REASON why a box of KELLOGS CORN FLAKES costs what it does ConfusedConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 6:17pm
Amen
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 5:24am
My previous employer had top heavy management, excused as to "Necessary to maintain a watchful eye of the Union Membership" as to screwing off or not performing duties that really did not exist.  Was in essence buddies employing buddies to make the most money from the corporation, so called "Golden Children" of Management.  Had a VP of Nuclear, a Chief Operation Officer, a Corporate Nuclear Officer, a Department head for every sub section Department the managers could concoct(Last count was 67), Plant Operation Senior Officer, Plant Operations Senior Manager, then had Superintendents, First Line Supervisors, On Line Supervisors, Efficiency Consultants, Working Foremen, Work Package Consultants, Work Package Adjusting personnel, Work Package Alignment Personnel and then the Union Technicians as Electrician or Welder or Mechanic.  That along with QC Inspectors watching every operation FULL TIME with same level of Sub Management.
Of 720+ plant employees, 145 were Union, Including Operations personnel, Store rooms and Clerical Staffs.  I seldom saw the Managers in plant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 7:41pm
Company I work is very close to 50/50 union/salaried.  Amazing part is we run around the clock and very easily can run a long weekend with out one of them stepping foot in the plant.  When COVID first hit and work from home was the big thing one of the salary gems got cau” working from home” on the golf course and another time camping.  Truth be told the plants run better and more tons get produced when it’s just us hourly folk around.
Edited by victoryallis - 15 Nov 2021 at 7:42pm
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2021 at 6:42am
John Deere made it's most recent offer public, I saw it on Farms.com  Looks pretty darn good to me.  COLA every 3 months?  Wow, worried about inflation much?  Awesome healthcare, big bumps to retirement, scheduled wage increases and scheduled lump sum payments.  Vote is Wednesday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2021 at 6:44am
There's putz operators and putz managers.  As there are good operators and good managers.  Just depends on who's grouped together where on what shift for what gets done for productivity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2021 at 7:13am
Strike ended, deal ratified 61% to 39%.  Gotta wonder what those 39% wanted!
This page was generated in 0.270 seconds.
