John Deere lawn mower charging
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: John Deere lawn mower charging
    Posted: 07 Sep 2020 at 12:45pm
I bought a gt235 John Deere lawn mower this summer. I really like how it cuts. But the battery light has been on and off.
So today during the rain I thought I'd clean up some small projects. This being one. I got my tester out. Tested the two wires coming from the fly wheel. 30 to 32 a.c. volts at a little less then full throttle. That should be good.
I tested the wire going to the battery. I had 12 volts there so I knew the wire was good. Started the mower and again I only had 12.4 volts.
Ah ha regulator is bad. I go get one from a junk mower. Put it in. Light is still on grrr. Bad regulator? So I tested the battery with it running and I have 14.2 volts at mid throttle. So that would say my regulator is good.
What might be keeping my battery light on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 2:44pm
bad battery ? won't take a charge( bad cell)...
swap out the battery. put old one on bench, measure it, then put on charger for 2-3 hours, it should read at least 13-13.5 volts. I toss an 1157 lamp on it after being 'charged' to get rid of the 'surface electrons' then read the DVM....should be 13.5-14 volts for a good battery. let sit overnight, if lower in the morning odds are a bad cell...
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 3:29pm
I never thought of or heard of that before, but a great idea!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 3:51am
cut the ends off a 220 cord, plug the cord in,  and lay them ends down inside just ahead of the battery and let it "charge"!
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 5:03am
 WHAT,,,,?Is this your latest version of ,,,,,,tannerite,,,???WinkWink
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 8:02am
To be Trademarked as Electrocite. LOL Wink
This page was generated in 0.205 seconds.
