John Deere engine design
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Topic: John Deere engine design
    Posted: 04 Apr 2020 at 6:58pm
I suppose i should be asking this question on a John Deere forum, if there is one, but i figure there are some folks that frequent this forum who know more about John Deere stuff than John Deere people do. And that is a real complement seeing as everything green is so goodWink. Just about every diesel engine that i have been around is a flow thru engine with the intake and exhaust manifolds on opposite sides of the engine. John Deere diesels have both manifolds on the same side. It doesn't make sense to me. Why do they do that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 7:11pm
It may have been a cost saving issue 50 years ago when they were still making gas 4020's ??   Can't answer your question, other than Caterpillar makes some modern engines the same way (3176/3196..C-10-11-12) , while other Cat engines are cross-flow. Many used to feel Deere's head design hurt their tractor pulling performance years ago, but since the 55-series and newer, they apparently have gotten their CFM numbers much better. AC returning the engine oil down the intake side kept the oil a little cooler than down the exhaust side. IH having their injectors on the cool intake side was better for efficiency. So, maybe that was Deere's reason....injectors on the cool side of the engine ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 10:17pm
...there are a lot of designs out there that ended up the way they did for no real reason....the designer decided he would do it "this way" just because that's what he came up with....not neccessarily from great wisdom
That's what my designer brother tells me
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 1:58pm
Some Ford diesels, and the Perkins on my 170 have the intake and exhaust on the same side, as well as the D15, D17, D19 diesels. There is not a real advantage to "flow thru". The air has to stop for the combustion cycle anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 5:40pm
Truth is that mother deere couldn't figger out how to cast a block for more than a 2 cyl block, so they hadda steal the technique, from Cat. Cat's price for learnin them was that deere was supposed to stay outta the crawler/construction equipment...  See how deere lives up to its deals, with competitors?Wink
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 6:40pm
I heard in the '70s, Steiger made a prototype 2wd tractor and tested it on farms around the Deere factory/proving grounds to communicate to Deere to stay out of the 4wd market, or Steiger would enter the 2wd market. Guess the scare tactic didn't work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 7:53pm
Yeah Im sure of that too
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 8:15pm
I can't agree Joe. Because it stops, that is all the reason more for easier paths to get going again. But I still think that the biggest reason for cross flow heads was for the cooler intake air. That's my opinion anyhow.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 8:32pm
From streetdirectory.com
A crossflow cylinder head is a cylinder head that features the intake and exhaust ports on opposite sides. The gases can be thought to flow across the head. This is in contrast to reverse-flow cylinder head designs that have the ports on the same side.
A crossflow head gives better performance, but the popular explanation put forward for this - that the gases don't have to change direction and hence are moved into and out of the cylinder more efficiently - is a simplification since there is no continuous flow because of valve opening and closing. But since there is overlap between the intake and exhaust profiles there is a point in which both valves are open. At that point the inertia of the exhaust gases leaving the cylinder helps to aspirate the intake gases into the cylinder. The other main reason for a crossflow's performance is that the ports and valves can be larger and its physical separation of the hot exhaust manifold keeps the air in the intake manifold cooler. Most modern engines are of a crossflow design.
Wink
I am a Russian Bot
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 7:47am
To me, a reverse flow head(manifolds on same side) is a left over design from the engine's roots as a gas engine. Typical gas inline engines have manifolds on same side to give the intake and exhaust an attachment point to keep intake warm for cold weather use.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 12:48pm
Now that's pretty interesting. Crossflow head design creates a scavenging effect.
Learning AC...slowly
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 1:36pm
It's just what I found. I still think the biggest positive effect is cooler air and of course more room for bigger valves
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 4:42pm
I have a lot of experience with race engines as well as a degree in mechanical engineering, so I feel qualified to make the following statements:
There are a lot of inaccurate statements in the above Quote. I tried to check the referenced site but it is a map website.
Most tractor engines do not have their valve on opposite sides of the cylinder. They are aligned length wise to simplify valve geometry.
There is not reverse flow since the valves are in the center of the bore.
The overlap is only at the end of the exhaust and start of intake cycle. While it does help draw in during intake, it does nothing for exhaust.
Just because it is crossflow does not allow more room for bigger valves or for more separation.
The exhaust flow in a normal tractor engine has to go vertically and turn to exit.
You can only way to greatly benefit from crossflow is to have the valves canted to opposite sides.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 9:22pm
I know the valve is the smallest point of flow but wouldn't you be able to open up the ports and possibly give a better direction of flow in a crossflow head then in a reverse flow if you are really try to dial in performance?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 9:29pm
Crossflow to most of us means intake and exhaust ports on opposite sides of the head, with the valves being in line front to back in the head. In the automotive world the valves can be on each side of the head (as well as the ports) instead of all in line.
Edited by DrAllis - 07 Apr 2020 at 9:30pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 9:36pm
The close proximity of the intake manifold in relation to the exhaust manifold in a non-crossflow vs a crossflow head has got to affect intake temperatures.
Wink
I am a Russian Bot
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 11:53pm
Cross-flow design does have several advantages, and it's disadvantages, but it's context-dependant.  Basically, EVERY V6 and V8 engine is a cross-flow design- exhaust manifolds on the outside, intakes on the inside.  There's a packaging necessity to the V-design- that included angle is precious real-estate.
An inline, especially an industrial engine, has some different character, and one of those is the camshaft position, and auxiliary power-take-off.  On an inline, the camshaft sits low, and close to the line of the block, with pushrods coming up one side of the bank.  A cross-flow head would have pushrods coming right through the area of either intake or exhaust porting... which makes for difficult plumbing in those castings.  By keeping the ports all on one side, the other is totally open for pushrods.  How is this different from a V?  Simple-  the V-engine's camshaft is in the valley, but higher up, and with the bore/stroke ratio of a V being opposite from an inline, the camshaft can be mounted farther from the crank centerline to the bonus of BOTH banks.
The biggest issue of intake and exhaust temperatures on a cylinder head, is what happens to the casting under that thermal differential.  Thin castings, low nickel, with large temperature differentials tend to crack pretty darned quick.  Efficiency from intake temperatures isn't such a big deal with respect to proximity of intake and exhaust runners-  the intake air is not spending enough time in the runner to gain substantial heat... and in industrial engines, exhaust heat is intentionally added to the intake charge immediately after the carb for purpose of turning those droplets into vapor.  Air charge temperature is really most important when dealing with pulling in air that is from some confined area on a really hot day.  Oxygen density can get pretty low if you're pulling in very hot air from within an enclosure... and if it's being turbocharged or supercharged, that mixture may wind up exceeding it's autoignition temperature well in advance of it's proper event point... the process of compressing the air increases it's temperature substantially, and THAT is a good reason to have an intercooler.
Industrial inlines, especially platforms designed for a variety of liquid and gaseous fuel options, will tend to 'like' being a common-side design, because the non-plumbing side will have a large open side reserved for ignition system or an injection pump... while at the same time, the plumbing side can be easily set up to integrate a turbocharger (er... 'altitude compensator').
An engine that runs overhead camshaft, doesn't have the pushrod issue, and very frequently, since the valves are acted upon only by rockers, having a 4-valve head, and cross-flow design, results in a very high volumetric efficiency at all speeds... the cross-flow design places intake and exhaust ports, particularly the valves, very close to the port discharge point, in that case, the port volume becomes 'too small' to yield any sort of 'tuning character' to the engine's power curve... it becomes a very free-revving engine.
Industrials generally aren't that way, and any inline industrial engine that has a lower end specifically designed for multi-fuel, will not be in any sort of operational application where wide span, flattish torque curve will be beneficial.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 5:28am
sigh, my head hurts from reading all the neat info in the replies....bad enough I can't member to pull the choke out on the D14 to start it NOW th ol brain is full of 'engine tech stuff' !Big smileThis forum and it's members seem to know everything about everything.....
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 6:05am
The 6.7L FORD (NOT IH) Powerstroke has the exhaust on the inside of the V and the intake on the outside of the V. (or so I have been told. Never had the hood open on one as I am not a Ford guy)
Assuming thats a true statement, what are the advantages there???
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 6:10am
So would the 426 HEMI be considered to have the valves canted to the sides?(with the spark plug in the middle?) Maybe one of the reasons this engine was so successful on the racetrack?
But then the 426 WEDGE actually did better on the dragstrip then the HEMI ever did so we could open up that can of worms lol.....
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 9:09am
I thought we were talking about diesel tractors.
Yes the hemi is a crossflow. One of the best. The wedge never did better on the strip. It just predated it.
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 10:37am
The design simplifies the exhaust track to the turbo and allows the turbo to sit down in the valley more and allows removal of the turbo easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 11:08pm
That is correct. The valve covers are the intake manifolds and the exhaust is all in the valley. The reasoning is the turbo is closer to the heat source to reduce lag time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 11:10pm
It definitely does not make it easier to remove the turbo. I can have a 6.0 turbo out in half an hour. 6.7 is closer to a 4 hr job.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 12:36am
Deere has hardly invented anything. What they are famous for is letting other manufacturers invent things and let them get the bugs worked out, then they copy it. It has seemed to work too.
JD was one of the last to sell a rotary combine. They said all those years that rotaries were junk and conventionals were the best. That was until they came out with a rotary, and all of a sudden they were the best. Same way with the 2- cylinder design. Any more that 2 cylinders were junk, until they started building 4 and 6 cylinder engines, then overnight they were the best.
I’ve always said that JD was far from the best tractor maker, but they beat the pants off everybody else with marketing. There is even a JD store in the mall. Ask any non farm kid what color tractors are, 99.9% will say green, and I bet they can’t even name another tractor brand besides JD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 7:57am
Compared to a 6.4 it’s easier I agree about the 6.0
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 9:42am
Amen m16ty. Same deal with big round balers and track tractors and flexdraper headers and just about everything they make. I got to hand it to them though when it comes to planters. When they came out with the double disc opener planter,that in my opinion was one of the top innovations in agriculture.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 10:09am
They got into tractors when they bought the Waterloo Gas engine Works in 1918.  With that they got the Waterloo Boy tractor, which was a successful design.  Deere's own experiments with early tractors were less than satisfactory (Dain).  They kept the basic Waterloo 2 cylinder design for the next 40+ years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 9:41pm
On the planters, they didn't invent that either. Jon Kinzenbaw (Kinze) did the research and found that most of the JD planter unit patents were copies on old designs by other manufacturers, and copied the JD planter unit exactly (after JD refused to sell him plater units). Of course JD sued Kinze over it, but Kinze won.
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 9:53pm
I always thought Deere got big because it seemed to me they got into easy financing and advertised it before the others. Remember the eighties when lots of big operators bit the dust? Around here there was sale upon sale of shiny green.
