John Deere 5425 mill not go into gear. |
Mrgoodwrench ![]() Orange Level ![]() ![]() Joined: 03 Apr 2011 Location: CHICORA PA Points: 2089 |
![]() ![]() ![]() ![]() ![]() Posted: 4 hours 12 minutes ago at 9:02pm |
I’m trying to help out my neighbor with his 5425. He was pushing some brush around with it and he lost all movement. It will start and run and has all hyd functions including the loader. All the fluids are full. The neutral light will change from on to flash when you come on and off the seat and will come on and off changing position of the gear/park lever. The light goes out when you shift the electric “shuttle” into gear. If you release the clutch(seems to be only electronic) for about 5 seconds with everything shifted in to a gear and a direction the red gear light comes on with an alarm. I believe this is setting a trouble code but cannot find a procedure to read it. This tractor is open station and does not have the “roll” switch I keep finding online. I know you need to put a fuse into f9 on the fender fuse box to start diag mode but can’t seem to find a procedure for reading codes. Any help would be appreciated
