It finally happened....
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: It finally happened....
    Posted: 21 Mar 2010 at 12:28pm
Was plowing with the D17D and #53 plow yesterday and the pin that holds the hook in the snap coupler slid out and the plow came unhooked....latches released and left the plow in the ground just like it was designed to do.  It's that time of year again to inspect  the snap coupler parts for wear and missing pieces and make sure the latches release properly.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 12:42pm
That pin slid out sideways.  I would think that would be hard to do with all of the pull force on it all the time.  good thing you weren't hurt, and the latches worked properly.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 1:03pm
Glad to hear that you didn't get hurt,Eldon. That could have been one serious situation! Thanks for the heads up for everyone else,so they might take the time to check things out before the plowing begins.  Rick
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 1:54pm
I put new springs in all my tractor's Snap couplers last year and looked at the cotter keys and pins at the same time. Look at the lift latches for ease of release too!
The Snap Coupler setup was a grate unit but it is 40 years or more old.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 2:03pm
I know it was a cotter pin that gave up on your's but the spring can be bad and you will not know it.
Here is a new with ACGO's part# for a WD/WD45 get one for all your tractors and be safe!!
Don
Edited by Don(MO) - 21 Mar 2010 at 5:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 4:54pm
If you look at the spring you can see the wear on sides of spring.
Don
orangepower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangepower Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 4:56pm
I had a plow come unhooked at the snap coupler but the latches didin't release, it thru the plow up on my back and damaged the fenders.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 5:52pm
Even though I know mine is in good shape, I always hook a chain from the front of the plow to the front axle, just in case!
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 7:32pm
These pictures came from Craig in MO, glad it didn't happen to me.  He was not seriously hurt as I recall.
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 7:39pm
He had a bad combination there with a snap couple plow and no lift arm latches. The lift arms are pinned so they can not release. With this kind of lift arm pin you really need to pin the plow hitch or run a safety chain.
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 1:53pm
that looks like it might have hurt a little!
1955 WD-45 with factory PS
