ISOTrack pin tool |
yzfarmgirl28
Joined: 15 Feb 2012 Location: wisconsin Points: 249 |
Topic: ISOTrack pin toolPosted: 15 Apr 2022 at 1:53pm |
Looking for anyone that is knowledgeable about track pin removal. Need to remove/shorten a H3 track. Any information or expertise advise appreciated.
Would purchase or rent any type of pin press available. Thanks |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55206 |
Posted: 15 Apr 2022 at 6:16pm |
If you are shortening a track, then the UC is already fubar, and now you are gonna tear up the sprockets, too! JMHO. Someone should be along to talk about the tool...
Joined: 11 Sep 2009 Location: illinois Points: 90565 |
Posted: 15 Apr 2022 at 7:03pm |
YEP... chain is stretched so it does not fit the sprocket... Removing a link does not fix the problem... might make it worse with a snug chain.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42254 |
Posted: 15 Apr 2022 at 10:40pm |
Master pin can be driven out with a BFH by using a pin held against the master link .
Next problem is if you need to remove one link of which end do you remove - as you will need to remove another link . That link removal will change the overall dimension of the track and the on-center measurement between links - WHICH MEANS - the SPROCKET PITCH to BUSHING On-center will be off and lead to wear on both sprocket and track .
Check the track to see if it has been turned in past - if not then have it pressed and turned at a track shop - to bring it back to close to acceptable specifications . OR CUT OUT 1 Link and ruin the ability to turn it later along with putting stress or rear case and bearings and damaging them beyond salvage later |
