ISO HD5 Starter
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Topic: ISO HD5 Starter
    Posted: 23 Sep 2016 at 11:03pm
Searching for a friend, a starter for a HD5. Old number 1109114, new number 1113312. IA 563 357-2616
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 7:33am
I have one it is missing the start button but it is complete otherwise 9two0 253 8one92
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 1:05pm
i HAVE 2 HD5 startor   use  with foot rode for pushing on switch
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 4:07pm
I found it was easier to replace full starter with late model unit M42 unit with solonoid as the foot switch is impossible to find - also between rebuild cost of old starter the M42 is available easily - see one listed on E bay for $99 - Somewhere I have couple of generators and starters but non-working core material -
 Any truck repair shop or bone yard should have the M42 off any Detroit Diesel or other heavy diesel engine - ones with adjustable nose cone to use .
1993788 42 MT Starter Reman
Edited by Coke-in-MN - 26 Sep 2016 at 4:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 6:07pm
Yep, you remove the cap screws on the nose cone, and rotate the body of the starter, to make the starter fit the application...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 8:30pm
Allen screws on the ones I've worked on
This page was generated in 0.582 seconds.
