Isky cam specs |
Page 123 5> |
Larry(OH)
Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Topic: Isky cam specsPosted: 29 Apr 2015 at 5:32am |
Found the specs to the old cam I had in the "open" class engine. Ran good, sounded great.
It was spec'd and ordered by someone other than me. I called Isky with the number and they gave me all the other information |
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
bigcountry48
Posted: 29 Apr 2015 at 8:23am |
What motor was the cam out of, and kind of cubic inches were you running with it?
1950 B, 1952 pulling wd, and 1954 wd45
Larry(OH)
Posted: 29 Apr 2015 at 12:30pm |
45 motor, nothing major not enough cubes for todays world. Pankey ended up with it
mgburchard
Joined: 14 Sep 2009 Location: Tennessee Points: 1123 |
Posted: 29 Apr 2015 at 5:34pm |
Larry why are you posting Pankey can specs Its amazing that if you google 175 cam specification you get this forum and Pankey saying that all cams being purchased when cam Dr. Are 280 advertised with .330 lobe lift . Nelson says that's a generic berry camshaft profile but Larry posted a Isky profile . The thing is 195 degrees duration stock in a 226 in a 326 ci can use 215 degrres duration and a 426 ci can use 235 degrees duration at .050 and they all three act the same .no such thing as to big a camshaft but vwrry much so thing as to little a engine.
Edited by mgburchard - 30 Apr 2015 at 10:48am |
Larry(OH)
Posted: 30 Apr 2015 at 7:45pm |
Mitch, I just put out there since I found it and didn't go looking for the other post. This is the cam you said that you didn't have anymore
mgburchard
Posted: 01 May 2015 at 5:57am |
If Mitch hasn't seen it I'll pass this last post on to him . Your correct cam is in a quick reving running pulling currently engine.
wi50
Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
Posted: 04 May 2015 at 8:00am |
You didn't take a degree wheel and actually measure the cam out with a degree wheel did you Larry?
Larry(OH)
Posted: 04 May 2015 at 2:16pm |
NO..This is just what Isky told me when I gave them the cust number and info. Whoever has it now could do it for us i suppose.
Mitch, who is running it now? |
wi50
Posted: 04 May 2015 at 3:53pm |
That answers a lot. If you were to call isky and send them a cam you would not get anything like that grind for a flat plane, 180* Siamese port engine like this. Somewhere there's a mis communication and error. Wrong specs were given
No offense to you Larry, but prank should know better.....of course he will lie through his teeth also and purposefully give bad information. We've seen it many times on here. The way these engines are configured limit the available time we have available for the induction events. An engine with individual ports can tolerate more duration. A 6 cyl Siamese port can tolerate more duration. But a 180* or flat plane crank simply can't. You see there is overlap of the intake and exhaust valves, then there is overlap of both intake valves on a port at the same time that one exhaust valve is open......you wind up with 3 valves open on 2 cylinders opened together. In a sense, to much duration will "airlock" the engine to where it's not going to run well at all. If you were to call any reputable can grinder or designer, you will get the same story. The way these engines are configured with the flat plane 180* offset crank and the Siamese port it is hard to run much duration. If it had individual ports, you could. If it were a 6 cyl inline you can run more. But anything much more than the mid 220's @ .050" isn't going to work. Edited by wi50 - 04 May 2015 at 3:55pm |
wi50
Posted: 04 May 2015 at 4:23pm |
Those specs you have listed also have a longer exhaust duration than intake duration. That works in a ford with a poor flowing exhaust. But on the case of the ac, its backwards. The exhaust actually flows quite well.
I'll typically try and have a cam ground with less exhaust duration than intake for this reason. This helps the engine by allowing a few more degrees of push on the power stroke before the exhaust valve opens and it saves some of the exhausts inertia to scavange intake air in on valve overlap. This also allows for just a few more degrees of usefull intake duration, without in a sense opening up the cylinders to one another. |
mgburchard
Posted: 04 May 2015 at 5:32pm |
Yep Pankey told you that you were doing way to much port work on the exhaust side if you remember of coarse a search would show it if you forgotten any Pankey says you learn from him fairly quick though
blue924.9
Joined: 22 Mar 2013 Location: George Iowa Points: 1089 |
Posted: 04 May 2015 at 9:28pm |
You should tell pank to come over to this site and inform us
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Larry(OH)
Posted: 05 May 2015 at 5:08am |
WI...no offense taken. I knew nothing about what I jumped in to with both feet and had a hard learning curve.
mgburchard
Posted: 05 May 2015 at 7:20am |
Blue you will just have to petition forum to let him back on to get his experience and knowledge
blue924.9
Posted: 05 May 2015 at 8:40am |
what?
Posted: 05 May 2015 at 10:18am |
Let me try an interpret........." Blue, you will just have to petition the Allis Forum members, to please let Panky back on the site to be able to write and share his vast experience and knowledge."
blue924.9
Posted: 05 May 2015 at 11:02am |
ohh okay makes more sense, here i was trying to revert back to my 1st grade self to understand that but since there are others here that can use punctuation and are efficient in grammar i dont have to anymore.
as for the petition i will get right on that, propose it at the next unoffical allis legislative convention
of course like every other convention there will need to be a 75 percent minimum majority rule |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5108 |
Posted: 05 May 2015 at 11:40am |
Is there anyone who has read this thread that doesn't think Panky is still here????????
mgburchard
Posted: 05 May 2015 at 7:15pm |
Larry the one Pankey spec for my 452 inch allis is 356 duration at .006 lift with ivo at 61.2 degrees btdc and ivc 115 degrees abdc
wi50
Posted: 06 May 2015 at 7:26am |
Well pankey is no genius. At least you boys can laugh and say "I worked on it until it didn't run". |
mgburchard
Posted: 06 May 2015 at 7:37am |
Seams to me he knows more about cams than you do. Larry post a spec of a different manufacturer than berry and its what Pankey said it was in the 175 cam spec topic .how long ago is that topic been seams you would have learned a little more by now on how all the shelve grinds are 244 duration at 50
Larry(OH)
Posted: 06 May 2015 at 9:07am |
MG...Can you get me the info on where to get one of those and someone to talk to about? I am getting things rounded up to build another engine. I am liking what your showing.
mgburchard
Posted: 06 May 2015 at 10:37am |
Sure Its a Pankey and Iskyderian project .Pankeys number is 423- two42eightfive96 or the number you have for Ron Iskyderian
Butch(OH)
Posted: 06 May 2015 at 11:33am |
Please post a video of that one running. It will take a super charger plus you two blow hards blowing in the intake ( a three charger set up LOL) for it to even fire with only 4 degrees of valve closer.
![]() Edited by Butch(OH) - 06 May 2015 at 11:34am |
mgburchard
Posted: 06 May 2015 at 3:41pm |
Lol that's funny butch . I knew you didn't know anything about engines . a 4 cycle single cylinder engine has 720 degrees of rotation to complete a cycle
blue924.9
Posted: 06 May 2015 at 4:19pm |
452 inch single cylinder engine my ass lol. What level of the drug lab did that come from?
mgburchard
Posted: 06 May 2015 at 4:33pm |
Blue no one said 452 inch single cylinder . I said a Cingle cylinder four cycle engine has 720 degrees and Pankey had me post those specs cause Marty said advertised duration back in the 175 spec forum was seat to seat as you can see at .006 lifter rise it's 354 duration seat to seat duration for any cam would be 360 degrees but its figured at a lifter rise not seat to seat
Butch(OH)
Posted: 06 May 2015 at 4:41pm |
No wonder you cant get cam timing right Pank, The degree wheel goes on the crankshaft, not the camshaft. We hadnt covered that for you but jee wizz? We assumed you knew something from watching engine build videos??? 356 duration = 4 less than a full turn. Blow hard boy or it aint goen to fire ,,,, blow hard. Life must be tough when you have to be hit over the head to learn anything
dont forget to add video of your Allis single cylinder engine with 356 degrees of duration |
Butch(OH)
Posted: 06 May 2015 at 4:46pm |
Saved for future generations.
mgburchard
Posted: 06 May 2015 at 7:22pm |
Larry Ohio did you call Ron about the 356 degree of duration at .006 lifter rise? Let us know the duration at .050 please
Page 123 5> |
