Is this part available. SC Blade?
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Topic: Is this part available. SC Blade?
    Posted: 22 Nov 2010 at 6:00pm
My old Snap Couple Blade is getting restored.  Wondering if anyone can give me a resource to locate this bolt block?  Mine has two broken bolts long rusted in as well as two that are stripped out.  Before I get too excited and go to working, I am hoping someone maybe has one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 6:07pm
This photo shows the other piece of the bolting assembly on the snap couple blade and you can see the bolting block without the adjuster frame in front of where i am pointing.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 8:22pm
  There are 3 ways,   first drill and extract,   second weld a nut to the bolt,   and the easy way is to take a pencil and draw it OUT!!  couldn't resist.   Good luck
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 8:40pm
I did kinda as has been sugested with mine...that is replace the threaded area with several nuts...ya gotta cut away the threads and "space" the bolts with the part with the holes in it ....I actually had a professional welder do it even though I weld...it has been too long and I don't have a welder that would penetrate.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 9:16pm
Allen (Draw it out) LOL That is funny right there.
There was a man parting one out on the old site. Can't remember the name maybe Andy from N or S Carolina. I bought a handwheel and angle plate from his blade.
Doug northern IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug northern IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 10:08pm
Would helicoil work, just wondering
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 10:24pm
You might get lucky and try electrolisis(sp) to 'draw' the rust out of the threads. I've done it a few times seems about a 50-50 deal. Heck ,let it cook overnight...can't hurt anything !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 9:48am
If it was just broken bolts and rust, I would be dreading the project.  The additional mess of stripped threads means drilling out and tapping unless the helicoil is used. That is getting busy!  I  am going to work on the rest of the blade assembly and if a decent block does not turn up for sale, I'll have a project for the machine shop.  That is a big drill and tap.
sks72107 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sks72107 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 1:12pm
Wow, im sure my dad would make short work of this.  Honestly this looks easy compared to having to fix %80 of the broken bolts that hold the side panels(under gas tank) on my d17.  All are broken flush with frame, no i didnt do it.  But i sure do cringe when i think about when it comes time to fix these.  Good luck, perhaps a little Kroil penetrating oil. I think you can fix without welding. $0.02
Shannon
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 8:13pm
you could always just weld it together  thats what most ppl did when they got tired of fixing the bolts weld will be stronger so it wont break as easily just my two cents
NICKMI
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 9:50pm
And last but not least,put studs in rather than bolts.I have studs with fine thread on the outer end.Loctite the inner.Have nylock nut outside. Mine have never worked loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 4:48pm
Take it off and take it to a machine shop. There's one close to me that can fabricate or repair just about anything. Something like that would be a quick and easy fix in a mill. A couple plunge cuts and and tap out the remains.
