Is this one "salvagable",,,,,? |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13759 |
Topic: Is this one "salvagable",,,,,?Posted: 19 Feb 2026 at 6:48pm |
I recently bought a 6" table top grinder that looked like a brand new piece as the green paint looked like new and the motor spun easily when turned by hand,,,,,It had two new wheels,, a fine grinder wheel and a wire wheel, both looking like not been used. Get it home,,plug it in and there is a loud buzzing noise coming from motor while trying to turn. Have my helper plug the cord in while I spin the wire wheel with a screw driver as he plugs it in. Motor tries to turn and noise is same loud buzzing sound,,,,YIKES,,,!!!! Anyone got an idee if possibility of worthwhile repair,???
Codger
Posted: 19 Feb 2026 at 7:21pm |
Two possibilities and I don't know what type motor so FWIW.
If capacitor start, look at either the start capacitor, or the centrifugal switch in the starting circuit. If split phase, look at the centrifugal switch in the starting circuit. In a single phase electric motor starting current must be shifted some number of degrees, (approaching 90) to start the rotor rotating and this phase shift is shifted out by the starting switch. These switches can, and do go bad.
That's All Folks!
Ken Mn
Joined: 10 Nov 2021 Location: Zumbrota Mn. Points: 13 |
Posted: 19 Feb 2026 at 7:22pm |
If it has a start capacitor it could be a bad capacitor. However I have a grinder that gave me the same problem. The start switch inside the motor works with a centrifugal mechanism that moved on the shaft because a set screw came loose. Take the motor apart and check it out. Good luck.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42226 |
Posted: Yesterday at 1:47pm |
Most of the small grinders have that switch rather than capacitor , it's a set of fingers that are centrifugal force acts on to get motor turning then switch to run after a certain RPM
desertjoe
Posted: Yesterday at 4:48pm |
Hey GUYS,,Thanks to all of ya'll for helping me,,this one has the "finger" set up with two springs that push against a plastic ring that pushes against the contact point ring that closes some points and sends power to the start windings,,,,???? this switch pushes against a set of contact points being fed by two green wires coming from inside motor. When I opened the end bells this "switch" would not move on the motor shaft. Is thois "switch" suppossed to be able to slide on the motor shaft or be anchored on the motor shaft???? What is it that MOVES this switch back and forth on the motor shaft so it can close the points????
Joined: 11 Sep 2009 Location: illinois Points: 90140 |
Posted: Yesterday at 8:19pm |
one plate is FIXED... and then there are two HALF PLATES on most that are spring loaded.. the half plates are fixed on a hing pin and then PIVOT in and out with the springs holding them IN at no speed, and flying OUT when motor is at run speed.. try to wiggle or pivot the half plates....
there are variatings, but basiclly this is it.
Posted: Yesterday at 8:20pm |
Posted: Yesterday at 8:32pm |
and when the WEIGHTS on the plate / springs fly OUT.... they open / close a set of POINTS or CONTACTS for the "start"... make sure the CONTACTS are clean..
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18958 |
Posted: 2 hours 55 minutes ago at 8:23pm |
Have you tried beating on it with a BFH? I'm just kiddin Joe! Been a long while since I gave you some chit. Hope you get it figured out.
