Is the D19 supposed to be + ground
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Is the D19 supposed to be + ground
    Posted: 10 Dec 2011 at 11:47am
Looks like my D19 is positive ground and according to the manual, that's the way the wiring diagram shows it.   Just making sure that this is correct as I am thinking of ordering a petronix ignition for it, and want to make sure I order the right one.  Also, for the gas tractors, did they just use one smaller battery that fit on one side, and the diesels used two, or did the gas tractors use two also?
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2011 at 11:52am
D19 GAS- ONE 12V BATT POS GROUND AS STATED - D19 DIESEL 2- 6  VOLT BATTS IN SERIES POS GROUND FRO 12 V SYSTEM AS WERE MOST GEN CHARGED UNITS OF THE 50/60'S
CFW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CFW Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 6:48pm
My D-19 gas is Positive ground. Has a battery tray big enough for two but previous owner of mine only used one so that's all I use. Turns over with power and speed. Starts good.
Better to remain silent and thought a fool than to type and remove all doubt! D17, D19, 190XT, 7060,& A.A.8610
Cmart009 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cmart009 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:07am
Had a question related to this; We recently took the battery off of our D19, but can't remember which way it goes back on. You said a positive ground; Is that with a generator or an alternator? We have an alternator on ours, so we only assume that it's a negative ground. Any info would be great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:26am
The posts are different sizes. If you just set each cable on a post, without wrenching on them, you should be able to determine which way it was hooked up.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:57am
tractors with alternators are negative ground. If you have an alternator then yours has been switched to negative ground.
Wink
I am a Russian Bot
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 8:44am
   The D19 came from the factory 12 volt, positive ground, charged by a generator. If it now has a alternater, 99% chance it is now negative ground.
Edited by Rfdeere - 23 Feb 2012 at 8:46am
http://www.rumelyallis.com
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 9:25am
http://www.allischalmers.com/forum/forum_posts.asp?TID=46067&SID=1215226z74a39z359a8bfa27ddzf93787152778&title=d19-with-alternator-negative-or-positive-ground
If it has a generator, be sure to flash the generator to set its polarity to match the battery after connecting the battery and before running the engine.
Gerald J.
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 4:31am
Just check which way the coil is.
This page was generated in 0.087 seconds.
