Is it a D-14,D-15, or D-17 |
Goat farmer n Ky ![]() Bronze Level ![]() ![]() Joined: 13 Oct 2011 Location: kentucky Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Oct 2011 at 8:36pm |
OK I'm brand new,Looking for help. I bought an AC from a family that their father had just passed away. they knew nothing about tractor....So here goes It's 4-cly. gas.4-speed with hi n lo on right side lever, has 3-point hitch, PTO.wide front end. has front end loader.Rear tires are 28's(by data page it's D-17) Has curved gear
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
The serial number is on the left side on the torque tube where the engine bolts in. You may have to scrape the paint. It will tell you the tractor model and serial number which we can then give you the year of the tractor.
Pat the Plumber CIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Springfield,Il Points: 4930 |
Never seen a D-17 with a curved shifter.D-14 or 15 would be my guess.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Calvin I found the numbers ,where the tractor bolts together(just in front of the shift pattern,left sidedown near the floor board...the numbers were stamped into the flange of rear section......the number is to large for a 14 or 15 , but a 17 doesn't have a curved gear shift.....am I looking in the wrong Place....
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
First off, WELCOME to the Allis Discussion board. There is a wealth of knowledge on here.
Look at the rear of the engine on the left side, between the carb and the fuel filter bowl.
The serial # will be stamped into the flange of the torque tube. Like Calvin said, you might have to scrape paint to see them. On my D15 it would be above where the clutch rod goes into the torque tube and a little toward the front. Bob
Thanks Bob, for the welcome and the "correct" location...first thing tomorrow I should have my answer........Dave
ChuckLuedtkeSEWI ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Here is where the serial number should be. Should start with d14, d15, or d17 then a space and a the serial numbers will follow.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
allisorange ![]() Silver Level ![]() ![]() Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
I wonder if you have a 170?
John Carlson
Found the numbers...couldn't quite make out the D but it is a 14..1958 model...kinda disapointed...hoping for more HP...but it runs good every thing works PS,PTO.3-point hitch,front end loader and 3 new tires.....but needs paint and decals ..been changed to 12Volt (GM Alt. & batt. I'm sure starter is still 6 volt )...Paid $2,000.....Hope it will lift 4x5 bales....has 2-way power on bucket...I don't think I got hurt.....Thanks for the help...Dave
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Sounds like a good deal to me. You might have to put something heavy on the 3 point to keep traction on the rear wheels.
Allis Express participant |
Raer's are not loaded..but have hay spear for rear and on bucket....so I think I'm OK there....this loader looks like part of the frame holds fluid also..is this common?
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
The tractor's hydraulics have high pressure/low volume system so the rear lift doesn't work a loader like a more modern tractor would. So, it's common to use a loader with a front mounted engine driven pump to get good hydraulics for a loader. Also due to the front mounted pump it's common for the loader frame to be the reservoir for the loader.
