Invasive brush problem
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 11:37pm
if it is that small of stuff, get a skid loader anf get one of Cokes sons tree puller. the reason is his puller will out pull and outlast any on the market. mine has pulled approx. 1200 trees from 8 inch on down to 1 inch trunks in size and it still works/looks like new yet. if you go in and shred them, don't drive back in with pneumatic tired anything as all it will do is flatten tires. cutting and spraying them is labor intensive, pulling them and piling them is best. the piles will dry out for burning or if not burnt, create a good wildlife habitat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 8:01am
Too Hilly to get a skid loader in there. Would spend more time trying to get it off its side and back on it's tracks / tires
D17JIM2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM2 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 9:11am
I've used tordon RTU many time w/o the problem of killing the bushes or trees next to where i used it. But it is on the label as a warning.
CaseyCreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaseyCreek Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 9:21am
Bush hogs can take a lot.  I can show you what I have done in similar situations:
http://allischalmers.shutterfly.com/pictures/176
D17 Series III,D17 Series IV, 185
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 5:07pm
If it is European Buckthorn - unless it's killed to the root it will come back 2 fold it seems .
Just cutting it off and the roots send out several new stalks or trunks - the birds spread it as the black berries seem to be a diuretic and birds drop the seed which seems to grow instantly .
 I took a lot of it out with the backhoe before son built his puller for skid loader use.
He has modified a unit also to fit on front of utility tractors to mound on loader arms - so can build units for front or back of tractors
Edited by Coke-in-MN - 20 Apr 2018 at 5:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 6:49pm
If you can be there over a weekend, burn it on Friday and early Saturday.  That way you're getting rid of the crap while protecting the BIG trees.  It's a waiting game, but worth it.  PATIENCE,,,,,,,,,,,,,a little at a time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 8:43pm
If its that hilly, get some goats, and fence them in with a 'lectric fence...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 8:42pm
Maybe you could get someone in to cut the trees for the lumber and get them to clean out all the crap?
