Interesting Truck
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 9:00pm
I have 2 of them here one with working flat bed dump. The one with bed has hauled a million ton flag stone.It has had a hard life. I bought it because of the bed in 81 I thing.  But it did haul a good amount of grain for me. I think we kept it wound up to tight,cause it seemed to eat engines. It has big howl in the rear end from bearings being lose sometime in its life. Because 3 different drives in different comditions. But only one of them was a new built as a truck engine.
The original to me engine was 289 V8 that was from as mass rebuilder and was a year or 2 old. Then a junk yard 350 the the built 350 and finally a GMC V6 305 from junk truck. Changed the motor mounts and drive line to put the V6 in the other all just bolted up.
From what I have been told Chevy big blocks would bolt right in as well. So a engine transmission combo from any Chevy/GMC pickup until the new series engines in late 90 should drop right in.
The one truck has a set wheels that are tubeless 7 x 22.5 I think ,they look very narrow anyway. I could always find 9 x 20 easier and mounted myself on the super widow maker 3 piece wheels. Never had one let go but if no cage used a clip on chuck and a lot of log chain to tie it up.
I have been around a number of other Chevy/GMC 50,60, and 6500 trucks 1960 and newer all 4 speeds were the same as pickup trucks the 5 speeds were  little bigger. None of them were big on power in my book. The 292 straight 6 was not that much less than a 350 or 366.
Wink  have parts but you need to come pull them yourselfs.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 1:52am
IMO, the best engine for it was the 472 V6, and while they didn't ever COME with anything like it, a 6pd Allison overdrive transmission would be awesome... as would be about 5psi of boost, an intercooler, and any axle ratio higher than 6:10...  4.56 would be about perfect with a 0.8 overdrive and modern high-speed tires...
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 11:05am
I had a 1961 "C 70 with a 348 in it and it would blow the doors off any V6 of roughly the same size, even bigger. It may have been a special motor. I don't know, but it would get 13 MPG running around empty. Didn't check it loaded but it would pack the mail. It was checked by a car pacing it at 90 MPH pulling an empty small car hauler. (old) You would really like the torsion bar suspension because it will out ride any 3/4 ton pickup out there. It had the working 5 speed and two speed rear. It was never out run to my knowledge until it was junked long after I sold it. Dang I miss the old girl, but mostly I miss my youth.   Sigh........    Leon
iowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 12:01pm
A friend of mine had a simalar vintage Viking as a small boxed grain truck. Used it up until the mid-2000s when he was having issues with the brakes, had some sort of uncommen brake syatem- hydra-brake? Half air brake, half fluid system?
Anyways it was in good shape and ran great so I was interested in it but checked into fixing the brake system and as he had found out the parts were near impossible to find and expensive.
