Interesting Truck |
Page <12 |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4873 |
Posted: 10 Apr 2019 at 9:00pm |
I have 2 of them here one with working flat bed dump. The one with bed has hauled a million ton flag stone.It has had a hard life. I bought it because of the bed in 81 I thing. But it did haul a good amount of grain for me. I think we kept it wound up to tight,cause it seemed to eat engines. It has big howl in the rear end from bearings being lose sometime in its life. Because 3 different drives in different comditions. But only one of them was a new built as a truck engine.
The original to me engine was 289 V8 that was from as mass rebuilder and was a year or 2 old. Then a junk yard 350 the the built 350 and finally a GMC V6 305 from junk truck. Changed the motor mounts and drive line to put the V6 in the other all just bolted up. From what I have been told Chevy big blocks would bolt right in as well. So a engine transmission combo from any Chevy/GMC pickup until the new series engines in late 90 should drop right in. The one truck has a set wheels that are tubeless 7 x 22.5 I think ,they look very narrow anyway. I could always find 9 x 20 easier and mounted myself on the super widow maker 3 piece wheels. Never had one let go but if no cage used a clip on chuck and a lot of log chain to tie it up. I have been around a number of other Chevy/GMC 50,60, and 6500 trucks 1960 and newer all 4 speeds were the same as pickup trucks the 5 speeds were little bigger. None of them were big on power in my book. The 292 straight 6 was not that much less than a 350 or 366. I
have parts but you need to come pull them yourselfs. |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Posted: 14 Apr 2019 at 1:52am |
IMO, the best engine for it was the 472 V6, and while they didn't ever COME with anything like it, a 6pd Allison overdrive transmission would be awesome... as would be about 5psi of boost, an intercooler, and any axle ratio higher than 6:10... 4.56 would be about perfect with a 0.8 overdrive and modern high-speed tires...
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 14 Apr 2019 at 11:05am |
I had a 1961 "C 70 with a 348 in it and it would blow the doors off any V6 of roughly the same size, even bigger. It may have been a special motor. I don't know, but it would get 13 MPG running around empty. Didn't check it loaded but it would pack the mail. It was checked by a car pacing it at 90 MPH pulling an empty small car hauler. (old) You would really like the torsion bar suspension because it will out ride any 3/4 ton pickup out there. It had the working 5 speed and two speed rear. It was never out run to my knowledge until it was junked long after I sold it. Dang I miss the old girl, but mostly I miss my youth. Sigh........ Leon
iowallis
Joined: 04 Jun 2017 Location: North Iowa Points: 387 |
Posted: 14 Apr 2019 at 12:01pm |
A friend of mine had a simalar vintage Viking as a small boxed grain truck. Used it up until the mid-2000s when he was having issues with the brakes, had some sort of uncommen brake syatem- hydra-brake? Half air brake, half fluid system?
Anyways it was in good shape and ran great so I was interested in it but checked into fixing the brake system and as he had found out the parts were near impossible to find and expensive.
Page <12 |
