intake manifold on 7060
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: intake manifold on 7060
    Posted: 24 Oct 2025 at 9:14pm
So I'm putting an inner cooler off a 7060
on a 220 and it has some sort of an probe for lack of
knowing what it's actual name is but I think it is the ether
injector maybe,any help would greatly appreciated.
This one is broke off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2025 at 7:43am
Ether atomizer. It's brass. Carefully drill it out I guess. How are you going to connect up the coolant flow on a 220 water pump?? or is this a newer Mark II engine from a 7000 series??
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2025 at 7:49am
Yes,likely the ether injector. You could leave it, block it, or drill it out. It's made of brass so it would drill easily but getting the chips and pieces out of the manifold could be a chore unless you have the inner cooler disassembled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2025 at 9:48pm
I haven't got to that bridge yet Dr Allis.
Yes I have the cooler out of the manifold.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 2 minutes ago at 6:46pm
Been there done that. Have a 3500 MK II engine in my 220 that I added an intercooler. To get proper flow, you will require the big waterpump that only discharges to the left side. Now you will need to move the lower rad inlet from the right side to the left side. While I was at it, I recored the rad with 7 rows. to finish it off the alternator is now on the right hand side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 52 minutes ago at 6:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 34 minutes ago at 10:14pm
Calvin, your 220XT evidently uses a cam driven oil pump. Was the original engine like that too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 22 minutes ago at 8:26am
My original 220 cam driven oil pump engine is now in my 210. The engine shown is "On Highway Spec" with the crank driven oil pump and the inline injection pump. It had 82 original hours when installed
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 11 minutes ago at 8:37am
Im confused. That last pic shows a camshaft driven tach cable and that can't happen unless it's a cam driven oil pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 7 minutes ago at 8:41am
I suppose the Harvey engineers could have offered a dummy tach drive option driven by the camshaft ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 27 minutes ago at 10:21am
That's what was confusing me too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 34 minutes ago at 11:14am
For those who haven't been into one of those engines, there is a hollow spot in the block where a cam bearing could have been, but instead the camshaft driven oil pump gears  were instead.  The story goes that any of the tractor pulling blocks (with 4 turbos/200+ psi boost) that failed, usually failed in that area of the block from lack of cast iron.
