intake manifold on 7060
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: intake manifold on 7060
    Posted: 21 hours 60 minutes ago at 9:14pm
So I'm putting an inner cooler off a 7060
on a 220 and it has some sort of an probe for lack of
knowing what it's actual name is but I think it is the ether
injector maybe,any help would greatly appreciated.
This one is broke off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 31 minutes ago at 7:43am
Ether atomizer. It's brass. Carefully drill it out I guess. How are you going to connect up the coolant flow on a 220 water pump?? or is this a newer Mark II engine from a 7000 series??
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 25 minutes ago at 7:49am
Yes,likely the ether injector. You could leave it, block it, or drill it out. It's made of brass so it would drill easily but getting the chips and pieces out of the manifold could be a chore unless you have the inner cooler disassembled.
This page was generated in 0.039 seconds.
