Installing WC brake bands
Message Reverse Sort Order
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Installing WC brake bands
    Posted: 27 Feb 2011 at 7:52pm
the easiest way was to tie some thing to the band before you pulled it out, then you could tie it to the new one to help it make the turn. I have fed a coat hanger around the drum, then used it to pull them around. I did mine butt first, I don't believe there is room for the stud to go around
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:49pm
tie a piece of wire to the loop end and fish it through, keep wire in center of drum and pull on wire as you feed band down and around drum.    David
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:33pm
What is the easiest way to install WC brake bands?  Should they go in bolt first or the other way?  My I&T manual does not say.  I tried both ways today and probably did not do enough forcing to get the band around the drum.  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
This page was generated in 0.227 seconds.
