installing v8 in wc allis chalmers
EVERETT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EVERETT Quote  Post ReplyReply Direct Link To This Post Topic: installing v8 in wc allis chalmers
    Posted: 18 Oct 2010 at 4:03pm
Has anyone out there installed a v8 engine in a wc allis chalmers and if so how did you do it and what parts were needed?
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 5:06pm
there was on sitting in Plainfield for sale. looked like a ford motor. Next time I'm over that way I'll see if there is a number
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 5:16pm
The WD that I saw this summer with a V8 had a plate between the motor and bellhousing about 1/2 or 5/8 thick that changed the bolt patterns. Basically the same way you put a Ford or Chevy motor in a Jeep.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 5:40pm
The bell housing comes off the tranny on a WC I believe. Drill new holes in your V8 bellhousing to match your WC tranny.
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 7:34pm
you could probably install the v8 with automotive trans easier thatn adapting it to the allis, but it could be done either way.  Auto or manual.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 9:03pm
I've seen a C with a smallblock Chevy in it, or should I say a small block Chevy with a C built around it.LOL! If that can be done, you should have no problem putting a V-8 in a WC.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 11:00pm
 This is my idea of the perfect WC engine  2-71 Detroit
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 11:40pm
Coke I like that idea. Let me know when it gets done!
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 1:56am
i have a WD with a chevy 6 cyl in it...and it has 2 stick tranny's for some reason. i bought it this summer on a sale, haven't had much time to look it over yet or even start it up. to previous owner drove it in parades so i know it runs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EVERETT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 8:03am
ok if I do that then what about the side pulley and the bell housing are very much different such as the allis is deep for clutch and such the v8 is just the clutch by looking I may a little slow at this and I dont want to tear up an antique like this real bad next is if I take the allis tranny out and then spline the turbo 400 or 350 to the rear end of the tractor will that work?
Gatordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatordoc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 8:40am
Ive got a wd I built with a 455 olds engine with a turbo 350 Igutted the tractor trans and hooked the auto to the pinion made the adapter from the back of the auto to tractor I had to widen the frame but it is all stock length
Post Options Post Options   Thanks (0) Thanks(0)   Quote EVERETT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 9:00am
Thats what I thought so how much did you have to widen because this is what I want to do its just a lawn ornament sitting there and this will be good what about your mounts were are they on the front of the 455 or on the side? And the tranny did you just run a new mount accross the frame?
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 9:08am
 A V8 in a WC sounds like a fun project. I stopped a little short of that with a six pack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EVERETT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 9:25am
so there is light at the end of the tunnel Thanks so much a picture says a 1000 words whats the adapter plate from
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatordoc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 9:42am
I had to widen it adout 4 inches. I welded the same size channel on the outside of the original frame rails and then cut out the old rail in the area it needed to be wider. I then tapered the ends of the new rail to the old and laid a piece over the whole thing. The mounts are on the block to inside of the frame. The back of the trans is bolted tight to the adapter I made.  The adapter takes place of the trans tailshaft housing and has a bearing to suport the coupling and pinion/tractor trans mainshaft. When I get home tonigth I will try to post some pics
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 9:54am
Since the chevy wants to run 3 or 4 grand for power, likely one of the two transmissions is left in 2nd gear for a about a 2:1 speed reduction so that 3 to 4 grand speed goes to the second transmission in about the same speed range as the original engine.
Gerald J.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 10:19am
" this is what I want to do its just a lawn ornament sitting there "  If its just going to be a lawn ornament, then just set the engine in on the rails and forget it... Would save lots of time trying to make the adapter plates and mounts. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote EVERETT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 10:45am
No that what it is now. After all this time and effort it will NOT be just a lawn ornament and I appreciate all or any information I get Thanks
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 6:11pm
Not a WC, but one of the cleanest installations I've seen. This tractor could drive up behind you and you could barely hear it. It was whisper quiet. Also note the hydraulic pump on the pulley location.
This was at Hutch a couple of times, and at Almelund this past summer. We talked to the owner, and he uses the tractor regularly, and drives it to shows within 20-30 miles. It's a very nice tractor.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 6:20pm
 Innovative way to handle steering !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 8:05pm
Thanks for sharing that GB. It is a super clean install. Lot of time and effort. Very well done. Governor? What would you get a governor from? I would imagine they would have some sort of industrial application that one could get a working governor from.
Also, I noticed the exhaust manifolds seem to be flipped over. I was wondering if that would work. I want to put an Inline 6 in the parts C that I have. I know where there is an old derrick hoist engine that would have governors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 7:07am
You can still buy belt driven governors. Last I looked Valu-Bilt carried them. But they may not now.
Gerald J.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 7:29am
Gerald J.
I have a few used belt driven goveners for sale.  Richard
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 8:25am
A lot of combines were powered by truck engines, especially the chevy straight sixs.  Most of them had belt driven governors.  Old L and C model gravelys did as well as an option.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 8:45am
some Massey-Fergusen combines used a Chevy 350 which would have had a governor on it...thinking mid to late 60's
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 9:16am
I knew there had to be a source. As far as getting the right RPMs for power, a chevy or Ford 6 in the 292/300 inch range would probably need around 4,000 rpm to make the most power, though both are strong on the bottom too. I would think a V-8 would definitely need a higher RPM to make the most HP.
I'm not an expert when it comes to the way the governor works. I know the flyweights work with the engine speed to keep the RPMs constant, and the RPMs are regulated by the linkage position and the amount of tension in the spring. I'm just not really clear as to how to set one up or get the right one for the speed you want.
Edited by DREAM - 20 Oct 2010 at 9:17am
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 9:19am
I have always thought this one was a great conversion. He did a very nice job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 10:42am
http://www.valu-bilt.com/product_info.php?product_id=7786&item_number=A%201005925 pricier than I remembered but that can be the basis for further searching if you need a new one.
DREAM, the throttle linkage has a spring to pull the throttle plate open with that spring tension varied by the hand throttle. The governor works on centrifugal force that when the engine speeds up the weights move out and are coupled to counteract that spring tension to close the carburetor throttle. Same thing happened on a steam engine. Often there is a second weaker spring to dampen the response so the automatic control doesn't oscillate.
Gerald J.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 3:40pm
Theys a flattop wc in mcminville with a 454 in it . he says he blows  alot of 3 rd gears out but the wc had a truck tranny so it pretty easy to find gears.
This page was generated in 0.099 seconds.
