Installing seat pivot bolt bushing on WD45 |
| Author | ||
StanGreen
Topic: Installing seat pivot bolt bushing on WD45Posted: 06 Nov 2023 at 10:28pm |
On my WD45, I had a worn out seat pivot bolt bushing. After may hours of effort, I got the old bushing out. Again, I spent many hours trying to get the new one back in. Only to end up destroying it. A new one is on order. So, rather than destroy another one, what is the best way to get this bushing back in the seat bracket? BTW: No, I don't have a hydraulic press nor do I want to buy one.Thanks, Stan
| Sponsored Links | ||
JimWenigOH
Posted: 07 Nov 2023 at 4:54am |
How about a large, heavy duty c-clamp, or a hydraulic jack under something very heavy to push against. A repair shop that would do it for you at minimal cost. Bring it to my place in Ohio, I'll press it in for you.
Edited by JimWenigOH - 07 Nov 2023 at 4:57am |
Mikez
Posted: 07 Nov 2023 at 6:25am |
Did you put the new bushing in the freezer overnight before trying to install
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5060 |
Posted: 07 Nov 2023 at 6:30am |
Can you pull it in with a fine thread bolt, some washers and a lot of lubrication? If you have a dremel tool, clean the hole up good before you start.
Edited by WF owner - 07 Nov 2023 at 6:31am |
StanGreen
Posted: 07 Nov 2023 at 7:53am |
Thanks for the ideas. I actually bent the handle on my C clamp trying to press it in! (Part of how I damaged the first one.) It also tends to want to twist under pressure, so the force goes sideways rather than straight. I do have a auto shop I take all my vehicles to, so I'll give them a call.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5250 |
Posted: 07 Nov 2023 at 9:29am |
I have my local machine shop do jobs like that if I don’t feel comfortable doing it myself. With the correct tools they could have something like that done in a minute. Mine wouldn’t probably even charge me and would say see ya next time.
StanGreen
Posted: 12 Nov 2023 at 7:08pm |
I ended up finding a shop that would do the work. Not "local" but close enough. They had trouble with it even with all their equipment! They said the bushing "bulged" when they tried to press it. It did end up getting it in but I did not ask how! I don't know how they did them at the factory. But it is done now and I will likely never have to do it a again on this tractor.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4148 |
Thanks(1)
Posted: 13 Nov 2023 at 8:11am |
Changed one on one or the other of mine some years back. Not a fun job! Sounds like mine was easier than yours though!
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7540 |
Posted: 13 Nov 2023 at 4:03pm |
x2 I have said it before. Local machine shops are invaluable when dealing with old tractors. Worn out parts? They can build them up. Parts not available? They can make them! Yes, they can be expensive, but what in life today isn't? Two things are certain: good looking repairs and good quality workmanship. |
StanGreen
Posted: 13 Nov 2023 at 4:43pm |
Dakota Dave
Posted: 13 Nov 2023 at 8:03pm |
to late now but I cleaned out the eye with sandpaper on a flapper lubed it with dish soap and pressed it in with a hydraulic press.
AC720Man
Posted: 13 Nov 2023 at 8:32pm |
Glad to hear that you got it in. My local machine shop has been an incredible asset while rebuilding these ole tractors. Most times they can rebuild a part for me for far less than a new part if its salvageable. They have rebuilt some parts that are NLA. I can’t thank them enough.
