inside and outside latch for chicken coop
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: inside and outside latch for chicken coop
    Posted: 27 Aug 2025 at 11:37am
 I have seen some door latches that can open from inside or outside of chicken coops,,,,? Anyone got any ideas,,,,??
        k
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 1:00pm
https://www.tractorsupply.com/tsc/product/speeco-two-way-lockable-gate-latch-3603506
Something like this? I would think a smaller version is surely available. Or you could make this work if the gap isn't to big around the door
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 3:32pm
 Hey Tyler,,,Thanks for the quick reply,,!
 This factory coop from TSC came with a sort of latching device like something I aint ever seen,,
 It has a 1" long of 1" dia piece of metal pipe that you have to PUSH AND HOLD "UP" to open the gate,,,when you let this piece drop, it falls into a space that a "PIN" then keeps it from sliding UP to open the gate ,,,,,Biggest problem is when you are inside the coop, refilling water or groceries,,it is almost impossible to reach around the 1" square tubing frame using BOTH fingers and thru the frame to push up and hold the sliding metal barrel while pushing gate open and keeping the chickens from running outside past you,,,,!!!!  Really Rube Goldburg apparatus,,,!! Easy to open on OUTSIDE but HE## to open from inside,,,!!!
  I have seen some on ranch gates that use about 3/8" rod or 1/2" strap shaped in a U that  straddles the gate post with a handle on inside and outside,,,but my engineering mind cannot come up with a solution,,,,
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 3:51pm
Joe,
something like this?
Pretty simple
sorry about the sizing.
Edited by LouSWPA - 27 Aug 2025 at 3:53pm
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 3:57pm
Basically, a sliding bar with a dowel through it. there is a slot cut in the door and the dowel (handle) is able to slide the bar from inside or outside.  That is what was on our outhouse when I was growing up
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 4:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 4:09pm
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2025 at 7:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2025 at 11:32am
https://mobileimages.lowes.com/productimages/4fca4789-a44d-48f3-889a-782e18e3cb30/43180622.jpg?size=mpdhi
I should've thought of those Thad. They were on every chicken house door in the country for DECADES!!! Work very well
Edited by thendrix - 28 Aug 2025 at 11:33am
