Injection Pump Question
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Topic: Injection Pump Question
    Posted: 13 Nov 2016 at 2:26pm
Question: Should the fuel being pumped out of the injector lines be pressurized, or only after it exits the injectors? In other words, is it normal for an injection pump to pump fuel at a "flow" rate out of the injector lines our should it be squirting out?
-Slim
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2016 at 2:37pm
Keep in mind that the injector lines are much larger than the injector tip. I've opened lines and seen the fuel come out in what you might call drips.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2016 at 8:42pm
The pump pumps unknown amount of pressure. The injector dumps the pressure when it gets to pressure the injector is set at (1250-3750 or more). There would be no end to the pressure the pump could pump. Until line or something else gave.     MACK
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:34am
Like mack says.....Imagine a garden hose running, then put your thumb over the end of it. The injector is like your thumb.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:48am
A general rule in any hydraulics, pumps create flow, not pressure. The pressure is created by a restriction, in this case the injector. Now, if you're trying to bleed a diesel fuel injection system and it still won't start, there is a good chance the fuel coming out the injection lines is just transfer pump flow, not actual injection pump chamber volume/flow. When they are working right, there's pretty good amount of force coming out the injection lines, so they should squirt out the lines with authority. Just dribbling may indicate the injection pump isn't pumping the volume it is supposed to, either it's worn out, or something is sticking.
This page was generated in 0.570 seconds.
