Inj pump swap
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Topic: Inj pump swap
    Posted: 15 Nov 2011 at 9:34pm
I am thinking of swapping the Roosa-Master pump on my 7080 with a Simms pump. The Roosa-Master is set at 210hp, and the Simms at 350. I dont plan on pulling any larger equipment or going any faster. The main reason is for the "out of field" 15 and 16000lb class, a few times a year. I can get the pump, lines and gear for a good price. What do you think? Good? Bad?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 9:57pm
You'll need larger injectors too if fuel delivery is set that high....probably 4 hole x .020" diameter.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 10:16pm
You could run into turbo over speed problems too, with that much more fuel going through.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2011 at 10:09am
A 3LM466 would be a nice fit. I have one I'd sell.
