Inj pump swap |
Dans 7080 ![]() Orange Level ![]() Joined: 05 Feb 2010 Points: 1146 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Nov 2011 at 9:34pm |
I am thinking of swapping the Roosa-Master pump on my 7080 with a Simms pump. The Roosa-Master is set at 210hp, and the Simms at 350. I dont plan on pulling any larger equipment or going any faster. The main reason is for the "out of field" 15 and 16000lb class, a few times a year. I can get the pump, lines and gear for a good price. What do you think? Good? Bad?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22101 |
You'll need larger injectors too if fuel delivery is set that high....probably 4 hole x .020" diameter.
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
You could run into turbo over speed problems too, with that much more fuel going through.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5113 |
A 3LM466 would be a nice fit. I have one I'd sell.
