Initial vvle setting on assembly of 160?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: Initial vvle setting on assembly of 160?
    Posted: 21 Dec 2010 at 2:44pm
I am slowly getting the D 15 II motor back together.  tody I finished torquing the head and put the rocker assembly on.  I got the Jensales manual and thought I would just look up the intial assembly setting instrctions.  Something like bring No 1 to TDC on compression stroke and adjust valves so and so.  then move the crank to and set the rest.
I did not find anything.  Can somebody give me a stear in the right direction for the initial assembly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 2:50pm
jees vvle = valve
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 3:15pm
the best way is to adjust each cylinder in turn at top center in-.008-.010  ex-.014-.016 hot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 3:17pm
in-.012  ex-.018  cold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 5:51pm
Dang, I guess I had my gears in neutral.  that will work Dave.
I was jut thinking bck to yesteryear when you could do tht easy/less rotating method on the small block chebies.  happy holidays.
