Info on Allis 8070 please
eldon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eldon Quote  Post ReplyReply Direct Link To This Post Topic: Info on Allis 8070 please
    Posted: 30 Apr 2018 at 8:20am
I bought a 2wd Allis chalmers 8070 tractor a few years back, and I got nothing but only good things to say on this machine. great tractor, but I had a few questions.
My first question are the oil filters. I change the two slip/turn filters beside eachother but was told there is another filter ? (some bypass filter perhaps) I never did change that.
Question 2
Lately I have been having this tractor coming out of gear when the tractor is working relatively hard.
it is a 5 speed , with that power direct lever on the left side of the steering wheel. also sometimes when I shift into low on that lever the tractor comes out of gear?
I would appreciate any knowledge on this, as I really do like this tractor and it has been working very well and want to continue having this machine going
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 3:46pm
Engine oil bypass filter is above the starter on the left side of the engine. It is BIG compared to the other 2 engine oil filters.  As far as "coming out of gear" goes.....unless your 1-2-3-4-5 lever or the High-Low-Park lever are moving to the neutral position on their own, it isn't coming out of gear.  I'd suspect you might have a wet/oily torque limiter clutch disc and it's slipping under a hard pull. The next time it does this, quickly see if your power steering is sluggish or dead. If so, it's a slipping torque limiter. Shift down a gear to maybe get thru the Spring season.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 8:59pm
What gear is it coming out of? 1-2-3-4-5 or hi lo on right console?   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote eldon Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 8:57am
The tractor comes out of gear in 5 high shifting down to low on power director as well as the power director at times will not switch to high , which I forgot to mention in my post . Also in 3 and 4th gears in high in the high power director at high revs I'll be working In field and the fast/slow selector lever will knock back into neutral
This page was generated in 0.115 seconds.
