Indefinant Backorder (engine Kit) AGCO
 Post Reply Post Reply Page  <1 234
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 4:12pm
I do not stock the kits as many dealers do not .I drop all the kit that I sell across the so called counter. Only order in what I need for the shop .
nonetheless ,still dead.
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 4:42pm
is it a power crater piston or not??? and how long were you gonna let me suffer before we discovered this kit? I GUESS THE BIG SECRET IS OUT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 4:58pm
   8.25 .   Ware house dose have them . Just checked .
              Call me 717-451-6590 .For any more information 7 am to 8 pm eastern time .
Edited by Fred in Pa - 22 Oct 2015 at 6:41am
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 6:57pm
Originally posted by Fred in Pa Fred in Pa wrote:
   8.25 .   Ware house dose have them . Just checked . Call me 717-451-6590 .For any more information 7 am to 8 pm eastern time .
Hey Fred can I order just one oil ring and not a complete set of piston rings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 9:38am
Parts list says you can order a set (one pistons worth) for $25 i think
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 11:17am
There is no big Secret.                 Looks as all information had been posted early on in the post.
                                   All one needs to do is know just what they want to do and order from any dealer they wish.
        There is search for dealers on the Power Max site to find one near you.    .Good luck with what u are going to do with ur engine.
Edited by Fred in Pa - 22 Oct 2015 at 7:52am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 11:12am
I just (finally) got set up as a Reliance (Powermax) dealer and placed my first order for a couple tractors I'm working on.
If I can help anyone, let me know!
Edited by WF owner - 21 Oct 2015 at 11:13am
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 8:39pm
well not to stir the pot lol,but what was the final decision on what engine kit to use for the engine overhaul?
Edited by ac45dave - 21 Oct 2015 at 8:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 10:14pm
Im gonna try this power max kit. I havent ordered yet. I gotta wait to hear from my machinist on bearing size. I will post once I get it in. Im hoping its what I want... still havent confirmed if its a power crater style piston. Nobody seems to know. Guess ill be the guinea pig. It is 4" bore and 8.25 comp
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 11:02pm
I would like to see it too! Tracy
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 6:39am
I have been a Power Max Dealer for 14 years .I was waiting to see where this post was going .
Just curious...........why were you waiting?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 9:26am
When you get it up and running, run a good compression test on it with throttle full open and battery charger connected.....should be 170-175 psi cranking compression.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 9:38am
With todays lower grade gasolines is it necessary to use premium gas with 8.25 pistons?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 9:51am
Define "premium". I think with 87 octane fuel you'll be fine. 89 octane would be better yet. Ignition timing needs to be between 23 and 25 degrees BTDC at full throttle. Old D-17's were 30 degrees BTDC and they got updated to 25 degrees BTDC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 11:01am
Man that would be a bummer I hope not!     like the DR. says, regular gas should be just fine. you wouldn't expect to have to put premium in a Gleaner E3 or allis 175 Would ya?
On a side note gas down to 2.02 here today, I thought about driving my combine to town and fillin her up. beats 5 gallon cans and Cheap!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 11:43am
My D17 with the 8.25:1 AGCO kit runs JUST FINE on 87 regular.   So does my 8:1 z-code EIII Gleaner.   Thumbs Up  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 11:54am
dr allis,   what was allis's reason for the timing change?detonation,torque,or horsepower or a combination of things?
Edited by ac45dave - 22 Oct 2015 at 12:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 11:59am
i would think 87 octane would be sufficiant as most cars and light trucks have been running 8:1-9:1 compression for the last 35-40 years mainly do to emission standards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 12:35pm
They had all the information needed to find out what ever they wanted to know .I just sold one these kits this morning .Customer CALLED me and I answered every ? he had.   Thanks
Edited by Fred in Pa - 22 Oct 2015 at 12:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 12:41pm
Actually, 9:1 is getting low by todays standards. It's pretty typical to see 11:1 on non premium requirement engines. But then again combustion chamber technology has improved along with variable cam timing.
A 3.5 Ecoboost in the F150 is 10:1 with a pair of hair dryers...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 12:49pm
I don't believe you will ever find ANY other gasoline farm tractor that had more than 8 to 1 compression.....none. That ratio was apparently thee maximum that the AG Engineers figured any hard working farm tractor engine could stand without detonation problems on tractor fuel. In the case of the A-C model 175 gas, there was even a Service Bulletin instructing Dealer Techs to retard the timing 2 degrees if a Customer was having detonation issues. In the case of the D-17 engines, the retarding 5 degrees was related to center main bearing pounding with the increased compression from the WD-45 engine. The 2 degree retardation on the 175-170- D-17 means placing the FIRE mark or F-25 mark at the very top of the sight hole in the bellhousing. Please do NOT infer that just because your car can have 9 to 1 compression ratios means a farm tractor can too. Modern cars have detonation sensors to control the actual timing to keep detonation under control. Farm tractor timing on an A-C only has the RPM centrifugal advance to take it from TDC at idle to 25 degree BTDC at 1400 RPM or more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 1:01pm
Edited by Dmpaul89 - 22 Oct 2015 at 1:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 1:06pm
Thanks ,I am not good at typing sometimes about things to be said.
Edited by Fred in Pa - 22 Oct 2015 at 1:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 1:37pm
Today's engines have knock detectors and the timing is automatically adjusted to meet the conditions. No so in older tractors.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 8:52pm
You should advertise. I didn't even know you were in the business. Just thought you were a collector only.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 11:46pm
Back in the day when dad put 7.25 M&W's in WD45's he had to retard the timing.If you pulled it low and in knocked,you didn't retard it enough.He knew how far away from the F mark to put em.I was young and not paying attention.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2015 at 10:19pm
Hey, not to beat a dead horse...
I called into my AGCO dealer (Flieg's) in Ste. Gen. MO to order some other parts and while I had him on the phone I asked my parts guy Jerry what the deal was about the AGCO kits.  He did say the 170/8:1 kit was on indefinite back-order.   But the 7:25:1 D17 and the 8.25:1 engine kits were available according to him.   D17 Kit was $1178, part number 79015760.   175 kit was $1033.00 part number 79016625.   Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2015 at 11:33pm
Gas was $1.94 at Costco yesterday.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2015 at 12:17am
Well regarding the backorder. If it has changed that is news to me. I called at least 10 agco dealers in my search and all said the same thing that the d17 kit is discontinued. The 170 kit had 2 in existance and the 175 backordered indefinitely. Maybe I'll call again I guess there is a chance they ran another batch...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2015 at 7:00am
Hmmmm... I thought we had already determined that if any kits were available, they would have be aftermarket kits.
