Indefinant Backorder (engine Kit) AGCO |
Page <1 234 |
| Author | |||
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 19 Oct 2015 at 4:12pm |
I do not stock the kits as many dealers do not .I drop all the kit that I sell across the so called counter. Only order in what I need for the shop . |
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
| Sponsored Links | |||
Dmpaul89
Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
Posted: 19 Oct 2015 at 4:42pm |
is it a power crater piston or not??? and how long were you gonna let me suffer before we discovered this kit? I GUESS THE BIG SECRET IS OUT
Fred in Pa
Posted: 19 Oct 2015 at 4:58pm |
8.25 . Ware house dose have them . Just checked .
Call me 717-451-6590 .For any more information 7 am to 8 pm eastern time . Edited by Fred in Pa - 22 Oct 2015 at 6:41am |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 19 Oct 2015 at 6:57pm |
Hey Fred can I order just one oil ring and not a complete set of piston rings? |
Dmpaul89
Posted: 20 Oct 2015 at 9:38am |
Parts list says you can order a set (one pistons worth) for $25 i think
Fred in Pa
Posted: 20 Oct 2015 at 11:17am |
There is no big Secret. Looks as all information had been posted early on in the post.
All one needs to do is know just what they want to do and order from any dealer they wish. There is search for dealers on the Power Max site to find one near you. .Good luck with what u are going to do with ur engine. Edited by Fred in Pa - 22 Oct 2015 at 7:52am |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5057 |
Posted: 21 Oct 2015 at 11:12am |
I just (finally) got set up as a Reliance (Powermax) dealer and placed my first order for a couple tractors I'm working on.
If I can help anyone, let me know! Edited by WF owner - 21 Oct 2015 at 11:13am |
ac45dave
Posted: 21 Oct 2015 at 8:39pm |
well not to stir the pot lol,but what was the final decision on what engine kit to use for the engine overhaul?
Edited by ac45dave - 21 Oct 2015 at 8:40pm |
Dmpaul89
Posted: 21 Oct 2015 at 10:14pm |
Im gonna try this power max kit. I havent ordered yet. I gotta wait to hear from my machinist on bearing size. I will post once I get it in. Im hoping its what I want... still havent confirmed if its a power crater style piston. Nobody seems to know. Guess ill be the guinea pig. It is 4" bore and 8.25 comp
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10839 |
Posted: 21 Oct 2015 at 11:02pm |
I would like to see it too! Tracy
Lonn
Posted: 22 Oct 2015 at 6:39am |
Wink I am a Russian Bot |
Posted: 22 Oct 2015 at 9:26am |
When you get it up and running, run a good compression test on it with throttle full open and battery charger connected.....should be 170-175 psi cranking compression.
DougS
Posted: 22 Oct 2015 at 9:38am |
With todays lower grade gasolines is it necessary to use premium gas with 8.25 pistons?
Posted: 22 Oct 2015 at 9:51am |
Define "premium". I think with 87 octane fuel you'll be fine. 89 octane would be better yet. Ignition timing needs to be between 23 and 25 degrees BTDC at full throttle. Old D-17's were 30 degrees BTDC and they got updated to 25 degrees BTDC.
Dmpaul89
Posted: 22 Oct 2015 at 11:01am |
Man that would be a bummer I hope not! like the DR. says, regular gas should be just fine. you wouldn't expect to have to put premium in a Gleaner E3 or allis 175 Would ya?
On a side note gas down to 2.02 here today, I thought about driving my combine to town and fillin her up. beats 5 gallon cans and Cheap! |
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 22 Oct 2015 at 11:43am |
My D17 with the 8.25:1 AGCO kit runs JUST FINE on 87 regular. So does my 8:1 z-code EIII Gleaner.
Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
ac45dave
Posted: 22 Oct 2015 at 11:54am |
dr allis, what was allis's reason for the timing change?detonation,torque,or horsepower or a combination of things?
Edited by ac45dave - 22 Oct 2015 at 12:00pm |
ac45dave
Posted: 22 Oct 2015 at 11:59am |
i would think 87 octane would be sufficiant as most cars and light trucks have been running 8:1-9:1 compression for the last 35-40 years mainly do to emission standards.
Fred in Pa
Posted: 22 Oct 2015 at 12:35pm |
They had all the information needed to find out what ever they wanted to know .I just sold one these kits this morning .Customer CALLED me and I answered every ? he had. Thanks Edited by Fred in Pa - 22 Oct 2015 at 12:36pm |
Brian Jasper co. Ia
Posted: 22 Oct 2015 at 12:41pm |
Actually, 9:1 is getting low by todays standards. It's pretty typical to see 11:1 on non premium requirement engines. But then again combustion chamber technology has improved along with variable cam timing.
A 3.5 Ecoboost in the F150 is 10:1 with a pair of hair dryers... |
Posted: 22 Oct 2015 at 12:49pm |
I don't believe you will ever find ANY other gasoline farm tractor that had more than 8 to 1 compression.....none. That ratio was apparently thee maximum that the AG Engineers figured any hard working farm tractor engine could stand without detonation problems on tractor fuel. In the case of the A-C model 175 gas, there was even a Service Bulletin instructing Dealer Techs to retard the timing 2 degrees if a Customer was having detonation issues. In the case of the D-17 engines, the retarding 5 degrees was related to center main bearing pounding with the increased compression from the WD-45 engine. The 2 degree retardation on the 175-170- D-17 means placing the FIRE mark or F-25 mark at the very top of the sight hole in the bellhousing. Please do NOT infer that just because your car can have 9 to 1 compression ratios means a farm tractor can too. Modern cars have detonation sensors to control the actual timing to keep detonation under control. Farm tractor timing on an A-C only has the RPM centrifugal advance to take it from TDC at idle to 25 degree BTDC at 1400 RPM or more.
Dmpaul89
Posted: 22 Oct 2015 at 1:01pm |
Edited by Dmpaul89 - 22 Oct 2015 at 1:17pm |
Fred in Pa
Posted: 22 Oct 2015 at 1:06pm |
Thanks ,I am not good at typing sometimes about things to be said.
Edited by Fred in Pa - 22 Oct 2015 at 1:12pm |
DougS
Posted: 22 Oct 2015 at 1:37pm |
Today's engines have knock detectors and the timing is automatically adjusted to meet the conditions. No so in older tractors. |
Lonn
Posted: 22 Oct 2015 at 8:52pm |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8681 |
Posted: 22 Oct 2015 at 11:46pm |
Back in the day when dad put 7.25 M&W's in WD45's he had to retard the timing.If you pulled it low and in knocked,you didn't retard it enough.He knew how far away from the F mark to put em.I was young and not paying attention.
Skyhighballoon(MO)
Posted: 28 Oct 2015 at 10:19pm |
Hey, not to beat a dead horse...
I called into my AGCO dealer (Flieg's) in Ste. Gen. MO to order some other parts and while I had him on the phone I asked my parts guy Jerry what the deal was about the AGCO kits. He did say the 170/8:1 kit was on indefinite back-order. But the 7:25:1 D17 and the 8.25:1 engine kits were available according to him. D17 Kit was $1178, part number 79015760. 175 kit was $1033.00 part number 79016625. Mike |
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 28 Oct 2015 at 11:33pm |
Gas was $1.94 at Costco yesterday.
Allis Express participant |
Dmpaul89
Posted: 29 Oct 2015 at 12:17am |
Well regarding the backorder. If it has changed that is news to me. I called at least 10 agco dealers in my search and all said the same thing that the d17 kit is discontinued. The 170 kit had 2 in existance and the 175 backordered indefinitely. Maybe I'll call again I guess there is a chance they ran another batch...
DougS
Posted: 29 Oct 2015 at 7:00am |
Hmmmm... I thought we had already determined that if any kits were available, they would have be aftermarket kits.
Page <1 234 |
