Indefinant Backorder (engine Kit) AGCO |
Page <1234> |
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 15 Oct 2015 at 5:32am |
Is the power max 915144 kit the same as a agco 175 kit?
http://www.powermaxparts.com/DEMO/AC-226-E.html http://www.jensales.com/products/ep-915144-allis-buda-out-of-frame-overhaul-kit-allis-chalmers-g226.html From a quick glance it looks like it has a 4 inch bore with 8.25 to 1 compression. |
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 15 Oct 2015 at 6:11am |
don I did the same measurement but I also noticed that the bottom of the dish is actually lower than the flat top so all you gaining is the advantage of the dish shape if both pistons are 8:1 ratio there compressing the exact same amount of air and yes the dish would make a difference on a highly tuned pulling tractor but on a regular tractor or a hobby tractor you will never see the power difference ps mine got the flat tops and they work great
Lonn
Posted: 15 Oct 2015 at 6:57am |
That piston Don shows on the left is not a actually a OEM type D17 piston. Maybe height wise and bore but that dish isn't what Allis put in a D17. That looks like what the dish in a WD45 piston is. A D17 piston will look the same from the top as a 175 piston.
Wink I am a Russian Bot |
Lonn
Posted: 15 Oct 2015 at 7:01am |
Howard out of Iowa used to sell the OEM style and bore kits a dozen years ago or so. I have no idea if they still do or if they are even in business anymore.
Posted: 15 Oct 2015 at 7:08am |
At least Trevman is honest !! 110 psi versus 170 psi on 170-175 pistons. That my friends is a BIG difference. More power and better fuel economy.
Dmpaul89
Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
Posted: 15 Oct 2015 at 7:20am |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 15 Oct 2015 at 7:36am |
...there's always the option of trimming the top of a stock WD piston to get your 8.25cr....gotta be able to do some math...
Posted: 15 Oct 2015 at 7:42am |
A stock WD OEM piston is a flat top design.
Dmpaul89
Posted: 15 Oct 2015 at 7:54am |
Dmpaul89
Posted: 15 Oct 2015 at 8:05am |
If everyone who posted on this thread would call there local dealer and backorder a 175 kit. It would be problem solved. They need to see demand I dont blame them. my dealer parts guy says its on the verge of being discontinued. Now he also said if they do discontinue it that company who made the kits could reproduce and sell them aftermarket If they wish..
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5057 |
Posted: 15 Oct 2015 at 9:06am |
The D-17 piston Don pictured looks exactly like the ones in my early D-17. |
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 15 Oct 2015 at 9:30am |
That picture Don showed of the pistons is from my Series IV. That piston on the left is indeed an aftermarket 4 1/8 kit piston (with the infamous 6.5:1 CR to boot). I have the original 4" 7.25:1 Allis power crater pistons that came out of it when it was overhauled the first time back in 1997. When it was done in 1997, it had the wrong oil pump put in it (w/o the built in pressure relief valve). When Don had it open in 2013 to fix that, we found the sleeve o-rings were weeping. Once we went to the trouble to pull the sleeves it was going to be done right and got the AGCO 175 kit. Since they had maybe 50 hours on them, I saved the aftermarket sleeves, & pistons and bought new o-rings and piston rings and those will eventually go in my WD45 when it needs it. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
bradley6874
Posted: 15 Oct 2015 at 10:08am |
We don't need to compare a 175 to a d17 piston we need to compare a 175 piston to a new flat top piston we know the 175 is better than the 17 when I did my e motor the piston looked like don's picture but the dish was way lower than the flat top. the edge was better but the dish was worse average probley the same
Dmpaul89
Posted: 15 Oct 2015 at 10:29am |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 15 Oct 2015 at 10:31am |
Latter on maybe tonight I will post how to built a AGCO 8.25 to 1 piston and sleeve set from AGCO parts the pistons, sleeves, o-rings and piston rings will cost about $500.00 to do it with the part numbers and they are still available.
A flat top piston will not make the same HP as power crater piston will on the same amount of fuel used per hour. |
Dan73
Posted: 15 Oct 2015 at 10:36am |
Thanks Don that sounds really helpful. I am starting to get excited about the chances of getting all of my old tractors back up to snuff this winter. Man I have too many projects.
Posted: 15 Oct 2015 at 10:39am |
I have never ever felt the "Power Crater" design piston was a sales gimmick. It even has a different sound that a flat top piston engine, in my opinion.
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2095 |
Posted: 15 Oct 2015 at 11:06am |
I mean no disrespect but if it is for a d17then why do you need a 175 kit. if it is for a working tractor then the D 17 parts have been fine for all these years. if the tractor doesn't have enough power to get the work done in my opinion you need a bigger tractor. if its for a puller there are literally hundreds of different combinations you could use to make more power and I doubt a 175 kit is the best option.
DougS
Posted: 15 Oct 2015 at 11:13am |
The bottom line is that he's looking for Power Crater pistons. There doesn't seem to be an OEM or aftermarket Power Crater kit anywhere. If it costs no more to put a 175 kit in instead of a D17 kit, why not just use a 175 kit? If Don knows where to get a 175 Power Crater kit, I'd go with that. |
KenBWisc
Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1185 |
Posted: 15 Oct 2015 at 11:23am |
You may find it difficult to find 262 kit from AGCO as well.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Dan73
Well for my personal situation it is a work tractor. I could probably freshen up the motor and be ok. I might still do that. But if replacing the pistons will give me a little higher compression and a little more hp then that would be great. Yes it has been a stock d17 on the farm here for alot of years. But I also added a front mounted hydraulic pump to run the accumulator for my haying and I am running a NH 565 baler. The two are a little big for her as she stands today. As to the bigger tractor comment maybe that would be a good solution but I own the d17 and it does get the job done if I could give it just a little more power I wouldn't feel I was working it for all it is worth. No disrespect taken on my part I am simply trying to figure out what my options are right now and depending on what I find when I open her up. Right now mine has an issue where once it warms up I think some of the valves stretch and she looses compression. I am not sure but that is sort of how it acts. Once I finish the fall work I will be having a mechanic friend of mine look at it with me. I know if I redo the head I will do rings and bearing at the very least I won't just redo the upper half and leave the old tired lower half. |
Dmpaul89
Posted: 15 Oct 2015 at 11:26am |
I put a call in to a power max engine parts dealer. This company is owned by reliance. In the power max catalog they list 4" bore 8.25 kits. Part number 915144. Im waiting to hear back. This may be the agco kit in a different box. Thats what im hoping for anyway... I dont have a problem using a overbore kit in my tractor mrgoodwrench. But in the intrest of preserving allis' s power crater design I think this problem affects us all. The d17 is one of the greatest tractors made. And it goes hand in hand with the power crater pistons. if agco isnt going to make the kit anymore that means no more allis style pistons and we loose the most popular aspect of those engines
Dmpaul89
Posted: 15 Oct 2015 at 11:35am |
Just got a call back. That power max kit is 4" standard bore and they had a different name for the pistons but I believe they are the same as the power crater. The kit is 1020.00 it comes with everthing except valve components and it is a 8.25 comp ratio. Its availiable and ready to ship. All id have to do is find out which bearing size to get. This seems to be the agco kit guys!
Dmpaul89
Posted: 15 Oct 2015 at 11:43am |
Ill also add that this company also makes the overbore kits and they are $650 compared to the standard 4" kit which is $1020 I asked the dealer why the difference and he said purely supply and demand. Most go with the overbore assuming bigger is better. so more are made.
Dmpaul89
Posted: 15 Oct 2015 at 12:07pm |
Fields
Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Posted: 15 Oct 2015 at 12:11pm |
i have a allmost new set of 4 inch pistons sleeves and rings. ill check the numbers to see. as far as i know agco was the only company selling 4 inch sets.
ac45dave
Posted: 15 Oct 2015 at 12:26pm |
Dan73
Posted: 15 Oct 2015 at 1:03pm |
Did you try calling jensales from that link I posted above? That is the same power max kit listed for $915 they can try to say the Web page is out of date but I would argue that they have to sell it at the listed price. Would save you some money |
Dmpaul89
Posted: 15 Oct 2015 at 1:43pm |
I couldn't get it to load on my phone but yes now I see it on my work computer. This looks good! im going to call them
Dmpaul89
Posted: 15 Oct 2015 at 2:19pm |
Ok yeah confirmed the price at 915.09. This looks like the way to go. Man I sure wish someone would chime in on here that has used this kit. it is a 4" bore. both power max dealers I talked to said the kits are very good and they have very little problems. Interestingly the 7.25 kit from them is 1600 lol. I guess there are very few of those sold
Page <1234> |
