Implement paint? What have you used? |
Post Reply |
Don(MI)
Orange Level Joined: 15 Sep 2009 Location: Michigan Points: 3810 |
Posted: 13 Apr 2012 at 2:09pm |
Have multiple implements to paint up, and might get started in a couple weeks depending on what else is going on.
What is the best implement paint, for cost and durability, also non-fading?
Anyone have a good match for PO#1 and #2?
I would like a good paint, but don't want to spend money on PPG or automotive paint really. The SC equipment I have, will get scratched eventually.
thanks!
Galatians 5:22-24
"I got a pig at home in a pen and corn to feed him on, All I need is a pretty little girl to feed him when I'm gone!" |
John (C-IL)
Orange Level Joined: 11 Sep 2009 Location: Illinois Points: 1654 |
I've had good luck with Van Sickle on implements, not an automotive finish and it doesn't fade bad if the implement is in the shed most of the time.
ctbowles58
Orange Level Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
2nd on van sickle
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Gary in da UP
Orange Level Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Don, I built this utility trailer in 99, with used steel salvaged from an aircraft hanger left over when Kincheloe AFB closed. When the welding and grinding were done I sandblasted, primed and painted with X-O Rust from true value hardware. Adheres very well but it has lost its gloss. The products I used were alkyd enamel. Due to climate change, Al Gore and the EPA , I don't think that the newer , cheap paints would hold up this well. But if you can get some xo rust, try it. Gary
Don(MI)
I have heard of van sickle on here before, what hardware store carries this paint? I don't think I have seen this paint locally.
Gary, dang nice trailer, looks good!
Galatians 5:22-24
Gary in Texas
Orange Level Joined: 11 Sep 2009 Location: Burkburnett, TX Points: 630 |
Google Van Sickle, on the site is a dealer locator, using your Zip code
David Maddux
Orange Level Joined: 13 Sep 2009 Points: 2524 |
They have a near perfect match to Persian Orange1.
Don(MI)
Looked all over the site, and could not find a dealer locator??
Dave, you don't happen to know the paint code match for PO #1? thanks!
Galatians 5:22-24
B26240
Orange Level Joined: 21 Nov 2009 Location: mn Points: 3860 |
I also like the Van Sickle they have a hardner that goes with it helps with gloss and durability. I get mine at a Fleet Farm store and special order PO 1 . One must remember it's still hardware store paint and will not last like automotive paint, however as said if kept under cover will do well.
GregLawlerMinn
Orange Level Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
I have used the Valspar Restoration Series paint on several rehabs. Am not a painter and am color blind; however it went one very nice and looks good. Did 2 coats with no hardner and final coat with hardner (advice from a real good painter). Purchased the paint at Fleet Farm.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
sparky
Orange Level Access Joined: 13 May 2011 Location: So. Indiana Points: 1627 |
I purchase Van Sickle paint at Orshelins.
79fordblake
Orange Level Joined: 01 Jul 2010 Location: West Kentucky Points: 827 |
At work we are using Majic paint with Wet Look hardener. When it drys we scuff it and put on a Urethane Clear. Seems to be working great.
Post Reply | |
