I'm making smoke
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: I'm making smoke
    Posted: 01 May 2011 at 4:30pm
The D17D overhaul seems to have hit a snag. It makes a small amount of blue smoke cranking. It turns as fast as it ever did. If I feed it a whiff of ether it tries to run and makes alot of smoke and dies. That small whiff was always enough to fire it off in the coldest weather. I'm 99% certain the fuel system is fully primed. I put the engine in the tractor with the timing cover off and the pump drive gear off the cam. I spun the pump by hand until fuel shot out of all 6 lines. With the timing pin in place with the engine on #1 compression stroke, I put the gear on and lined up the marks. I also removed the window cover and rotated the pump til the marks were lined up.
Only thing I can think of is the pump timing is not right. Before I pull the front cover back off to check my timing, is there anything else I should be looking at?
The good news is I have the oil pressure relief valve close, it builds pressure like it used to cranking.
Edited by Brian Jasper co. Ia - 01 May 2011 at 4:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 4:39pm
Inj pump is 180 degrees out of time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:18pm
Thanks Doc, that was what I was thinking, just didn't want to take the front apart again. The pump shaft can only go one way can't it? I couldn't get lucky and slip the pump off, turn the crank 1 turn and slide the pump back in place can I?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:21pm
Should be able to remove pump and rotate engine one full turn and reinstall the pump.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:26pm
I always wondered why they didn't make a little offset or keyway in the back of the shaft tang so it only went into the pump drive only one way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:37pm
I better go buy a lottery ticket cause normally my luck is all bad. So now that I'm thinking about it, I should have taken the cover off the timing window and turned it around to where both marks were visible huh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 9:20pm
Yup.
