I'm back on the forum
Al in WMA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al in WMA Quote  Post ReplyReply Direct Link To This Post Topic: I'm back on the forum
    Posted: 18 Jul 2011 at 8:45pm
I want to thank all you Allis fans who sent messages to me in my absence.  Thank You!
IF I can relearn the photo upload process I'll show you the sweet One-Eighty that is the newest member of the family
For now,
Thanks again,
Al
Education is what you get when you don't get what you wanted.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2011 at 11:43pm
After 88 views and no replies I quess nobody cares except me.
Welcome back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2011 at 11:53pm
Crazy Harry probably cares too Jeff. Welcome back.
Posting Pictures
To post a picture from your computer, first click on  new topic + or post reply/ . Do not use the quick reply box at the bottom of a previously posted topic. At the top of the box that opens is a row of icons. In the middle of that row is a picture of a tree, click on it. A window that says image properties will open, if that window is small, maximize it so you can see everything in the window. Click browse and find the picture on your computer and open it. Click upload and a small window will open asking you to be patient, click OK in the small window. The picture will appear in the box on the lower right side(if not click preview). Check the width and height of the picture. If the numbers are greater than 800 wide and 600 high, the picture will not be seen completely on the forum. You can change these numbers but need to keep the ratio the same between them or the picture will be stretched. Click OK at the bottom and the picture will appear in your post. You can add text to the post before or after uploading the picture. It is easier to insert your text first. Now click post reply or post new topic and you are done.
 If you have your pictures on photobucket.com, you can go to the picture in photobucket  and copy the IMG file and paste it in with your text. This is the better way to do it because if you upload from your hard drive to this site, you will shortly run out of space and have to delete older pictures. Once deleted, they will no longer show up on your old post.
Charlie
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2011 at 12:24am
At least you have a sense of humor about it. Always room for more questions, comments and in site. welcome back
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2011 at 4:33pm
good to have you back Al in WMA
This page was generated in 0.085 seconds.
