IH chain drive replacement/spare?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: IH chain drive replacement/spare?
    Posted: 09 Jun 2021 at 9:06am
Anyone know where I can get one to have as a spare? I need to know the length prior but does anyone sell these anywhere?
I'd also love to know what model and year this thing is if anyone knows? the guy I bought it off of said it was a international harvester brand?
Also what gear should it be pulled in with a Allis Chalmers b1950?
It's kind of confusing because the large spoke metal wheels on front are paired with not matching wheels on the back ( not spoked metal) and it all looks to be original, it has rubber tube tires on the back?
Edited by Hunt4Allis - 09 Jun 2021 at 9:17am
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 11:14am
We had one very similar but newer with rubber tires. Don't know model number but I think your is just an older model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 11:40am
So after some searching I did find this which looks to be the exact same thing but with rubber on the large spoke tires so I wonder if mine is just missing the rubber?
This one was listed for sale in 2017 in New Zealand I believe... If I have the same hay rake I'd love to know the story on this thing!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 12:10pm
Just the chain? Should be able to measure a link and contact an outfit like Shoup for example and order new chain. The drive gears I can’t help you with.
Straanger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 12:21pm
Get excepted on redpowermagazine.com and post it there. If it’s IH, they’ll identify it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 12:57pm
Not familiar with that website? Or company?
Okay I'll look there thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 1:10pm
That’s the farmall/IH version of this site. Former IH engineers, factory workers, dealers. Current caseIH mechanics. All kinds of helpful people.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 1:29pm
Detachable link chain. I have gotten it from Tractor Supply. Shoup has it also.
1963D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 3:01pm
Its what IHC called just a 4-bar side delivery rake. The low rubber wheel version was a No.5. That chain was an odd chain called 72-1/2. I googled it and venders come up who sell it
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 4:06pm
There should be a number somewhere on those links and then you can google it and match it.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 4:17pm
I doubt that, that chain will ever need replacing. Maybe put a little heavy oil on it.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 4:57pm
I am not the expert but I think your front wheels were never meant to have rubber on them, they look like the standard steel wheel of the time. my 2 cents
JLS retired View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JLS retired Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 4:58pm
it is possible to wear those chains out. The loops will wear and stretch so the end of the next link can slide sideways just enough to lock it stiff; snap!
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 5:13pm
This is just simple old flat link chain that has been around for close to 100 yrs. Made for slower RPM's  Go to TSC and get a new roll(10') if you think it is wore out. Otherwise oil it up and rake hay if you ever mow it.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 9:23pm
I would say it was built in the early 40s. That chain will out last the rest of the rake.       MACk
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2021 at 5:46pm
That is a steel  one. There are some that are the same pitch I think but made of cast iron, they can break.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2021 at 6:05pm
In answer to your speed question------VERY slow! them old rakes were pulled by a team of horses! --- Ya, everybody stuck a hitch for tractor on them and started tearing them up!
We always pulled ours in second gear half throttle or less with a 1936 WC allis on 11:00 28 tires, so that should give you an idea how slow you need to go!
Faster than that it will self destruct! They were not made very good to start with but for horse use they worked fine. They do bunch the hay really bad ---kinda like a dump rake!
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2021 at 6:06pm
To tell if it is definitely International.....Look inside the big wheels and see if there is a stamp in the casting - big I with an H in the middle with a big C around it to form a ring. That is an International trademark on old old machinery. Like they said, this is old flat chain.....count your links and take a sample with you for size and go to an old hardware store or farm store and see if you can still buy it. It is not available near as much as it used to be......but if it is a popular size, someone should still have it.   Bluestem Farm & Ranch Supply store here in Kansas still had several sizes a year or 2 ago. That stuff will get so worn out that it just falls apart.....by that I mean worn so much that the links slide sideways instead of locking in place and it just comes apart. Keep your new chain well oiled for long life of service. Take a pump oil can and keep oil squirted on it.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2021 at 6:34pm
I knew I had this someplace on computer,  just took a while to find it (and clean it up a little)
