IH 464 V8 engine:to 7.3ltr Conversion
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Topic: IH 464 V8 engine:to 7.3ltr Conversion
    Posted: 22 Feb 2026 at 12:26pm
Maybe someone will know. I have a MV-446 IH engine that runs well but uses gasoline in copious amounts. I also have a 7.3ltr Powerstoke in a 2000 F-250 that runs well but the truck around it is shot. I'm wondering if I can take the flywheel housing from the back of the V8 gas engine and bolt it onto the diesel?
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2026 at 8:41am
Through a few hours of research on the internet, the dubious conclusion of "maybe" has been reached. It seems the original 6.9ltr, and 7.3ltr diesel engines were developed from this gasoline engine casting, but I've not been able to ascertain whether the block rear bolting pattern is the same. The International T444 series is basically the same and is drilled and tapped for an SAE flywheel housing to affix, or the Ford housing, but I cannot verify if the blocks destined for Ford trucks are the same. I've seen many OEM applications have slight differences to protect their interests though the basic structure is the same over many applications. As example, the casting bosses may be present, but not drilled and tapped in one application, but that operation completed for another with differing part numbers for the two differences.
Anyways, I want to repower my old air compressor from it's current gasoline Continental B-427 flathead six, to something more fuel efficient. This 7.3ltr "Power Stroke" engine weighs about the same and runs like a top. The truck is beyond repair as rusted badly.
Best way to prove it is pull two engines I suppose. Neither is a problem as I have a viable place for the 446 engine to go if cannot be used, and the 7.3ltr engine has strong possiblilty of repurpose should these two not go together easily.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2026 at 10:43am
The IH Medium Size trucks with a 7.3L used an adaptor Bell Housing to accommodate the Deeper Flywheel and had a slightly different bolt pattern.  Cannot swap a Ford 7.3 into a IH or a IH 7.3 into a Ford.  May be able to get some pieces to do but MV is not the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2026 at 1:03pm
I don't know much about MV engines at all. Had a few SV series over the years but a different animal than the MV. Years ago I did swap a T444 into an F-350 truck with a blown 7.3ltr and juiced it up into a smooth and powerful engine. I unbolted the original SAE 2 bell and flex plate from the T444, and readily replaced both with the Ford originals that mated to the E4OD trans in the truck. Nothing was different other than the color.
I've received differing opinions from a couple of websites so probably best to go ahead and yank both engines and have a looksee for myself. The 446 I have a home for replacing a worn out 404, and the Ford engine can be adapted, or sold off easily enough. Either way, both engines need pulled for project completions.
Thanks for the help.
Edited by Codger - 24 Feb 2026 at 4:23am
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2026 at 7:14am
The diesels will interchange, the Diesel to gas application not so much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2026 at 8:38am
I will find out for certain next week as the MV-404 engine this MV-446 is to replace is already pulled and the flywheel/flywheel housing should be removed today and be heavily photographed for me. The Ford engine has a destination also if I cannot make use of it so will pull it this next week for evaluation. The Ford chassis is a "pile" and becoming cumbersome to have around as the weather warms so wanting to rid myself of it.
Thanks,
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2026 at 8:57am
As I remember from a friend attempting this, has to do with the Dual Mass Flywheel/Flexplate affair for dimensionally then bolt sizing for attachment to Trans.
6.9s worked, 7.3s didn't.  Unless had a 1/1 Manual from/to Medium duty(IE 444) or a Auto, Allison or 4R100.  Were all manner of side steps he ran into trying to adapt from a 446 1700 Loadstar upgrade to 7.3 Electronic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2026 at 5:36pm
That dual mass setup was a cluster from the word "go". Changed several clutches because of failure of those if used heavy. There was a 13" diameter single disc conversion available and then the transmission was the weak link as the clutch no longer slipped, or literally came apart.
Both the MV-446, and 404 engines have the five speed transmission IH used in those days. Don't know the trans identifier but reverse is to the left and down. 1st is left and up, 2nd to the next slot right and up, then normal shift pattern. Close ratio gears coupled with the two speed rear(s).
The 2000 7.3ltr has a 4R100 trans behind it but that's not a problem to source an SAE flywheel for the engine; even if having to make one.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 10:19am
Both engines pulled and the MV-404 flywheel housing readily bolted to the Power Stroke engine without modifications. The MV-446 is installed into another medium duty chassis and should run later this afternoon, or tomorrow. I'll need to gut the wiring harness(s)  from the F-250, breadboard it down retaining only what is needed to make the engine run in it's new application, and discard the rest.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2026 at 8:08am
Talked to cousins and the MV-446 is running well and truck is back in service for them. New fluids in everything and both conveyor, and auger work well. I've not had time to work on my project but will get to it once things are caught up in the shop. New tires are scheduled for later in the week.
That's All Folks!
This page was generated in 0.268 seconds.
