Ignition |
CoreyI
Topic: IgnitionPosted: 03 Aug 2021 at 9:01am |
Hello everyone. I’m looking to convert my WD45 to electronic ignition. I plan on using the PerTronix kit and flame thrower coil. I am also switching the plug wires to graphite. Question is, do I have to run an external resistor with this coil and do I need to run different plugs ?
Thanks |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7643 |
Posted: 03 Aug 2021 at 9:24am |
No for both questions
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5282 |
Posted: 03 Aug 2021 at 10:06am |
Just be sure to get a coil for a 4 cylinder and the voltage of your tractor's system.
CoreyI
Posted: 03 Aug 2021 at 1:36pm |
Thanks guys
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 03 Aug 2021 at 1:51pm |
We can help you out with all that you're lookin' for. Visit our website. I build the spark plug wire sets for each cylinder. You don't need to use the Blaster coil although its a nice enhancement. Totally optional. If your 45' is still on the OEM 6VPG system, the stock coil will work fine. If you flipped it to 12V's, you'll need to hook yourself up with a 12V/3.0 Ohm coil that's internally resisted. We have them in stock also. Definitely don't want to use a ballast resistor. They didn't work under the hoods of 60's Automobiles, never mind out in the elements on a Tractor. An internal resisted coil (12V's) keeps Mother Nature out so the Tractor runs nice.
Steve@B&B bb-customcircuits.com
CoreyI
Posted: 03 Aug 2021 at 7:58pm |
Will do. Thanks
