ignition wires
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Topic: ignition wires
    Posted: 27 Jun 2011 at 1:53pm
I have what look to be the original plug wires on my C. They are steel wire braid with a cloth jacket. On the jacket there looks to be a thin coating of black rubber or asphalt coated substance. The 90 deg. spark plug terminal is also coated. Does anyone have any info on the original wires?
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 4:54pm
Sure if you scrape the wire you will find it's overplated copper wire with a rubber coating that is inside a cloth jacket. Cloth is then coated with a thin rubber coating to protect the cloth .
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 7:33pm
If looking at replacing them, be sure you get SOLID wire cables; not the carbon wire ones used on autos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 8:07am
We offer custom made spark plug wires if interested....
This page was generated in 0.049 seconds.
