If both fit, do you use the smaller or bigger oil
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Topic: If both fit, do you use the smaller or bigger oil
    Posted: 20 Jul 2021 at 11:20pm
I own both Ford & Dodge vehicles.....the oil filters for the Ford (Motorcraft FL1A) & Wix 51515 will fit the Dodges but they are longer
So is it better to use the bigger one on the Dodges.....thus resulting in more filtering capacity
and then I only have to keep 1 filter number?
dee_veloper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dee_veloper Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 11:32pm
So long as the filter is stated to work with the vehicle it can be used.  As to more or less filtering, length is not the only criteria.
If the vehicle manufacturer recommends a filter, then that is the preferred filter.  Others can be substituted, but it is the owners call.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 4:52am
Fit is one thing, work properly is another.  Make sure that it works, by checking on an oil filter interchange.  A bigger filter would be slightly better, but unless its listed on a trusted interchange, may do damage... JMHO!Wink
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 6:45am
I would image a slight difference in filter length would not make much difference in performance. But the filter length, may not be the only difference, one filter may have different interior design, it may be tighter, or looser filter media. Oil pressure by-pass valves may be affected when using a filter not designated for that engine.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 7:33am
unless a cross over chart shows them interchangeable, i wold not go there for previously stated resons
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 7:59am
Baldwin clearly says same filter, longer version so wouldn't they be the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 8:17am
YES they are... car manufacturers can use 2-3 different filters on the same motor in different vehicles.. Normally it is due to access to the area, or  trying to get more room between the filter and the other components.... It just makes sense that if one filter is 2.5 inches long and one is 3.25 inche long that you would get more filter material in the longer one.
You can always compare the SPECS... but if Baldwin says its interchangable, go for it !
This page was generated in 0.289 seconds.
