identify this engine and pump |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Topic: identify this engine and pumpPosted: 16 Nov 2025 at 4:00pm |
i picked up this engine and pump with some other parts pump dosnt fit that engine , what is the engine and what is the tank on it ? also it has a oliver looking color green paint that is under the orange. will this fit in my c ? was this some military spec. engine![]()
Edited by HudCo - 16 Nov 2025 at 4:10pm |
HudCo
Posted: 16 Nov 2025 at 4:13pm |
Posted: 16 Nov 2025 at 4:35pm |
There should be a s/n stamped on the engine behind the carb or on the left bell housing flange lip. The engine looks to me like a G-138 or G-149 to a D-10 or D-12. The Barnes pump has a diesel p/n on it. So, maybe a WD-45 or D-15 diesel ? The square drives shaft looks like an old Detroit diesel engine, but the p/n is clearly Allis-Chalmers.
Edited by DrAllis - 16 Nov 2025 at 4:39pm |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10921 |
Posted: 16 Nov 2025 at 6:07pm |
Very early series 1 D10-12 engine.Is it for sale? Thanks, Tracy
HudCo
Posted: 16 Nov 2025 at 6:57pm |
that pump does have kind of a detriot color on the other side
HudCo
Posted: 16 Nov 2025 at 8:17pm |
oil tank and the bottom coat of green paint it must have been some kind of industrail thing looking on the internet i cannot find a picture of a pump under the distributor houseing on any d 10 or d12 but looks like there was a pump mounted their
Posted: 16 Nov 2025 at 9:22pm |
The Detroit pump ( if that's what it is) certainly could have been because A-C used Detroit engines in construction equipment up until 1953. The green paint is confusing tho......
HudCo
Posted: 16 Nov 2025 at 10:44pm |
just looked up the parts on the oil tank was used on the industrail tractors and ethier power steering pump or auxillery hydralic pump
Les Kerf
Posted: 17 Nov 2025 at 7:36am |
Some lame observations: That large-looking coil seems to be somewhat more robust than the oil filter that it got shoved into. The pulley on the generator appears to be nearly the same diameter as the crankshaft pulley, which would result in a relatively slow RPM on the generator. The generator itself seems somewhat large as well (unless the photo perspective is confusing me). Is there any possibility that this could have been a 24 Volt system?
Edited by Les Kerf - 17 Nov 2025 at 7:40am |
Posted: 17 Nov 2025 at 8:07am |
D-10/ 5308 serial number should make the engine a G-149 cubic inch power plant. G-138 cubic inch was prior to D-10/ 3501.
HudCo
Posted: 17 Nov 2025 at 9:25am |
what is the dash backwards 2 or5 on the end of the serial number ? will this fit in a B or a C ? i bet this was one of those backwards tractor forklifts
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4582 |
Posted: 17 Nov 2025 at 9:40am |
The serial number is 10- xxxx not D-10, This makes it a 138 engine. The tank when the engine was installed in a tractor was used for the non draft sensitive live hydraulics.
Posted: 17 Nov 2025 at 10:07am |
If that stamped number (5308) is the chassis serial number, effective 10-3501 was the start of the G-149 engine. So, unless there's something I don't unnerstan, 5308 is newer than 3501.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35582 |
Posted: 17 Nov 2025 at 10:19am |
Pump appears a Fuel Transfer pump off a DD, 71 series. Changed many.
HudCo
Posted: 17 Nov 2025 at 1:16pm |
tonight i will measure the bore and stroke the was allready off it but i do have the pan
Posted: 17 Nov 2025 at 3:01pm |
Stroke is the same 138-149-160. The bore is different between all three.
HudCo
Posted: 17 Nov 2025 at 6:12pm |
3.50 bore , now will this bolt in my c
Joined: 11 Sep 2009 Location: illinois Points: 90614 |
Posted: 17 Nov 2025 at 6:29pm |
will it fit... YES
![]() Edited by steve(ill) - 17 Nov 2025 at 6:32pm |
Calvin Schmidt
Posted: 19 Nov 2025 at 8:43pm |
The stamp is on the engine flange.
10-xxxx is a 138 12-xxxx is a 149 14-xxxx is a 160 My early D-12 has the 10-xxxx in the engine and next to it on the torque tube is D-12 1886 . This is an all original D-12 including the tires
Edited by Calvin Schmidt - 19 Nov 2025 at 8:44pm |
HudCo
Posted: 20 Nov 2025 at 9:55am |
i think i am going to turn it in to a 160 when i start going throught it , i think i just need a set of rods to make the change for the piston pins
Posted: 20 Nov 2025 at 11:45am |
Block sleeve bores are bigger diameter on the G-160.
HudCo
Posted: 20 Nov 2025 at 11:58am |
well dangit could always do the counter bores if their is enought meat in the block. but a jump from a used 125 to a fresh 149 wuold be plenty as it does is chores just fine now how many differant valve sizes through the engine changes? did see some rpm changes
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 20 Nov 2025 at 1:50pm |
The same vale train kit works for everything from the 116-BE engine all the way up to the G-160. Now you can put bigger valves in the head if desired.
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 633 |
Posted: 22 Nov 2025 at 10:12pm |
My I400 backhoe has a tank like that for the power steering
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1777 |
Posted: 24 Nov 2025 at 7:09pm |
I bit more info to add and correct, additional info welcome! Decoding engine serial # on 'smallblock' power crater gas engines 10-xxxx = 138ci 12-xxxx = 149ci setup w/bypass oil in newer 234353 "dual use" block * 149-xxxx = 149ci setup w/bypass oil in old 227541 block 15-xxxx = 149ci setup w/full flow oil in newer 234353 "dual use" block * 160-xxxx = 160ci 3-xxxx = 149ci in h3 crawler H-xxxx = 160ci in h3 crawler * 234353 "Dual Use" engine blocks were backwards compatible and could be used with both bypass style and full flow oil pressure systems because they had the ports, passages and plugs for both styles.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
HudCo
Posted: 24 Nov 2025 at 8:13pm |
so mine would realy be 138 with bigger pistons makeing 149cu in with bypass lube system , so what would it take to turn it to full flow
PaulB
Posted: 25 Nov 2025 at 8:24am |
For anyone looking I have a NOS G-160 bare block available.
