identify this engine and pump |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3970 |
Topic: identify this engine and pumpPosted: 16 Nov 2025 at 4:00pm |
i picked up this engine and pump with some other parts pump dosnt fit that engine , what is the engine and what is the tank on it ? also it has a oliver looking color green paint that is under the orange. will this fit in my c ? was this some military spec. engine![]()
Edited by HudCo - 16 Nov 2025 at 4:10pm |
HudCo
Posted: 16 Nov 2025 at 4:13pm |
Posted: 16 Nov 2025 at 4:35pm |
There should be a s/n stamped on the engine behind the carb or on the left bell housing flange lip. The engine looks to me like a G-138 or G-149 to a D-10 or D-12. The Barnes pump has a diesel p/n on it. So, maybe a WD-45 or D-15 diesel ? The square drives shaft looks like an old Detroit diesel engine, but the p/n is clearly Allis-Chalmers.
Edited by DrAllis - 16 Nov 2025 at 4:39pm |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10854 |
Posted: 16 Nov 2025 at 6:07pm |
Very early series 1 D10-12 engine.Is it for sale? Thanks, Tracy
HudCo
Posted: 16 Nov 2025 at 6:57pm |
that pump does have kind of a detriot color on the other side
HudCo
Posted: 16 Nov 2025 at 8:17pm |
oil tank and the bottom coat of green paint it must have been some kind of industrail thing looking on the internet i cannot find a picture of a pump under the distributor houseing on any d 10 or d12 but looks like there was a pump mounted their
Posted: 16 Nov 2025 at 9:22pm |
The Detroit pump ( if that's what it is) certainly could have been because A-C used Detroit engines in construction equipment up until 1953. The green paint is confusing tho......
HudCo
Posted: 16 Nov 2025 at 10:44pm |
just looked up the parts on the oil tank was used on the industrail tractors and ethier power steering pump or auxillery hydralic pump
Les Kerf
Posted: Yesterday at 7:36am |
Some lame observations: That large-looking coil seems to be somewhat more robust than the oil filter that it got shoved into. The pulley on the generator appears to be nearly the same diameter as the crankshaft pulley, which would result in a relatively slow RPM on the generator. The generator itself seems somewhat large as well (unless the photo perspective is confusing me). Is there any possibility that this could have been a 24 Volt system?
Edited by Les Kerf - Yesterday at 7:40am |
Posted: 23 hours 30 minutes ago at 8:07am |
D-10/ 5308 serial number should make the engine a G-149 cubic inch power plant. G-138 cubic inch was prior to D-10/ 3501.
HudCo
Posted: 22 hours 12 minutes ago at 9:25am |
what is the dash backwards 2 or5 on the end of the serial number ? will this fit in a B or a C ? i bet this was one of those backwards tractor forklifts
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4559 |
Posted: 21 hours 57 minutes ago at 9:40am |
The serial number is 10- xxxx not D-10, This makes it a 138 engine. The tank when the engine was installed in a tractor was used for the non draft sensitive live hydraulics.
Posted: 21 hours 30 minutes ago at 10:07am |
If that stamped number (5308) is the chassis serial number, effective 10-3501 was the start of the G-149 engine. So, unless there's something I don't unnerstan, 5308 is newer than 3501.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34548 |
Posted: 21 hours 18 minutes ago at 10:19am |
Pump appears a Fuel Transfer pump off a DD, 71 series. Changed many.
HudCo
Posted: 18 hours 21 minutes ago at 1:16pm |
tonight i will measure the bore and stroke the was allready off it but i do have the pan
Posted: 16 hours 36 minutes ago at 3:01pm |
Stroke is the same 138-149-160. The bore is different between all three.
HudCo
Posted: 13 hours 25 minutes ago at 6:12pm |
3.50 bore , now will this bolt in my c
Joined: 11 Sep 2009 Location: illinois Points: 88754 |
Posted: 13 hours 8 minutes ago at 6:29pm |
will it fit... YES
![]() Edited by steve(ill) - 13 hours 5 minutes ago at 6:32pm |
