identify this engine and pump
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: identify this engine and pump
    Posted: 16 Nov 2025 at 4:00pm
i picked up this engine and pump with some other parts pump dosnt fit that engine   , what is the engine  and what is the tank on it ? also it has a oliver looking color green paint that is under the orange.   will this fit in my c ?  was this some military spec. engine
Edited by HudCo - 16 Nov 2025 at 4:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 4:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 4:35pm
There should be a s/n stamped on the engine behind the carb or on the left bell housing flange lip.  The engine looks to me like a G-138 or G-149 to a D-10 or D-12. The Barnes pump has a diesel p/n on it. So, maybe a WD-45 or D-15 diesel ? The square drives shaft looks like an old Detroit diesel engine, but the p/n is clearly Allis-Chalmers.
Edited by DrAllis - 16 Nov 2025 at 4:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 6:07pm
Very early series 1 D10-12 engine.Is it for sale? Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 6:57pm
that pump does have kind of a detriot color on the other side
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 8:17pm
oil tank and the bottom  coat of green paint  it must have been some  kind of industrail thing  looking on the internet i cannot find a picture of a pump under the distributor houseing on any d 10 or d12 but looks like there was a pump mounted their
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 9:22pm
The Detroit pump ( if that's what it is) certainly could have been because A-C used Detroit engines in construction equipment up until 1953. The green paint is confusing tho......
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 10:44pm
just looked up the parts on the oil tank  was used on the industrail tractors and ethier power steering pump or auxillery hydralic pump
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 7:36am
Some lame observations:
That large-looking coil seems to be somewhat more robust than the oil filter that it got shoved into.
The pulley on the generator appears to be nearly the same diameter as the crankshaft pulley, which would result in a relatively slow RPM on the generator. The generator itself seems somewhat large as well (unless the photo perspective is confusing me).
Is there any possibility that this could have been a 24 Volt system?
Edited by Les Kerf - 17 Nov 2025 at 7:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 8:07am
D-10/ 5308 serial number should make the engine a G-149 cubic inch power plant. G-138 cubic inch was prior to D-10/ 3501.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 9:25am
what is the dash backwards 2  or5 on the end of the serial number ?  will this fit in a B or a C ?  i  bet this was one of those backwards tractor forklifts
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 9:40am
The serial number is 10- xxxx not D-10, This makes it a 138 engine. The tank when the engine was installed in a tractor was used for the non draft sensitive live hydraulics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 10:07am
If that stamped number (5308) is the chassis serial number, effective 10-3501 was the start of the G-149 engine. So, unless there's something I don't unnerstan, 5308 is newer than 3501.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 10:19am
Pump appears a Fuel Transfer pump off a DD, 71 series.  Changed many.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 1:16pm
tonight i will measure the bore and stroke the was allready off it  but i do have the pan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 3:01pm
Stroke is the same 138-149-160. The bore is different between all three.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 6:12pm
3.50 bore , now will this bolt in my c
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 6:29pm
will it fit... YES
Edited by steve(ill) - 17 Nov 2025 at 6:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2025 at 8:43pm
The stamp is on the engine flange.
10-xxxx is a 138
12-xxxx is a 149
14-xxxx is a 160
My early D-12 has the 10-xxxx in the engine and next to it on the torque tube is D-12 1886 . This is an all original D-12 including the tires
Edited by Calvin Schmidt - 19 Nov 2025 at 8:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 9:55am
i think i am going to turn it in to a 160 when i start going throught it  , i think i just need a set of rods  to make the change for the piston pins
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 11:45am
Block sleeve bores are bigger diameter on the G-160.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 11:58am
well dangit  could always do the counter bores if their is enought meat in the block.      but a jump from a used 125 to a fresh 149 wuold be plenty as it does is chores just fine now    how many differant valve sizes through the engine changes?      did see some rpm changes
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 1:50pm
The same vale train kit works for everything from the 116-BE engine all the way up to the G-160. Now you can put bigger valves in the head if desired.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2025 at 10:12pm
My I400 backhoe has a tank like that for the power steering
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2025 at 7:09pm
10-xxxx is a 138
12-xxxx is a 149
14-xxxx is a 160
I bit more info to add and correct, additional info welcome!
Decoding engine serial # on 'smallblock' power crater gas engines
10-xxxx = 138ci
12-xxxx = 149ci setup w/bypass oil in newer 234353 "dual use" block *
149-xxxx = 149ci setup w/bypass oil in old 227541 block
15-xxxx = 149ci setup w/full flow oil in newer 234353 "dual use" block *
160-xxxx = 160ci
3-xxxx = 149ci in h3 crawler
H-xxxx = 160ci in h3 crawler
* 234353 "Dual Use" engine blocks were backwards compatible and could be used with both bypass style and full flow oil pressure systems because they had the ports, passages and plugs for both styles.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2025 at 8:13pm
so mine would realy be 138 with bigger pistons makeing 149cu in   with bypass lube system , so what would it take to turn it to full flow
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2025 at 8:24am
For anyone looking I have a NOS G-160 bare block available.
