Identify Lights |
Post Reply |
Dave (NE)
Orange Level Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2103 |
Posted: 17 Sep 2021 at 11:56am |
I picked up these lights a couple weeks ago and need help identifying them and what the fit on. The middle one and one on the right have orange on the mounting bracket. Appreciate your assistance. Thanks, Dave |
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4340 |
I don't believe any tractor manufacture made their own lights. I have seen many Guide Lite brand lights that look like what you have. I equate that shape light to crawler tractors from the 40's to 50's. But crawlers where more plentiful here than wheel tractors, so my not thing of them on wheel tractors means nothing.
Joe(TX)
Orange Level Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
They look like automotive fog lights from prewar.
Leadoff
Silver Level Joined: 14 Oct 2016 Location: Calgary Points: 248 |
Dave (NE)
The first one on the left sure looks like a D Series fender mount light. I found the manufacturers name stamped on the light body on the inside near the rivets.......CM Hall. Very robust design and were also supplied on Massey Combines and early Ford 9n Very hard to find these days!!!!
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
sparky
Orange Level Access Joined: 13 May 2011 Location: So. Indiana Points: 1459 |
The middle light looks like a rear work light of some sort.
Bill Deppe/AC Salvag
Orange Level Access Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 968 |
Agree, the left lite very much like the early 190's and D17 III and IV. The middle looks similar to early Case and Oliver tractors. Not certain about the application for the right unit
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3647 |
One on right is a rear work lite from a Case tractor from the early '50's. i have one identical. The center one looks like a rear lite from and Oliver. They used those lites with the flat lens.
Dave (NE)
Thanks for the responses. After looking at the light on the left closer and comparing it to a '17 Series IV light I do have, I believe you are correct in saying it is a fender mount light for the III and IV. I should have noticed that sooner. Will have to find an early 190 to make a comparison. As for the other two lights, due to the orange paint, makes sense that they are for an early Case. Thanks again. Dave
Dave (NE)
Any idea what the value of the Case/Oliver lights (middle and one on right) would be? I suspect they would be 6 volt, correct? Want to make sure before I test them to see if they work. Thanks, Dave
Ray54
Much safer to test with 6v as if they are and you use 12v they will blow and need a new bulb then.
It has been a while but in the crawler world I think $100 was the asking price for that style.
Post Reply | |
