ID |
D19allisowner ![]() Orange Level Access ![]() ![]() Joined: 12 Dec 2011 Location: NE IA Points: 3076 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Aug 2021 at 10:21am |
![]() Edited by D19allisowner - 15 Aug 2021 at 10:23am |
If you choose not to decide you still have made a choice.
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 5105 |
Not sure but if you try searching the casting number right above the flywheel it might get you started
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34238 |
My vote is Tecumseh
Tin shrouding is all gone so will run hot until cooks. Basing on gas tank and flywheel. |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88328 |
cylinder bolts to the crank case block... That is not common on most... Should tell you something.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3940 |
its a wisconson probley ah model
lets see the rest of the tractor
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54331 |
Ditto! Sometimes if you ID the machine, you can figger out what motor it is!
It's a home built machine that friend of mine has so seeing the rest of it's not going to do you any good.
Tad Wicks ![]() Orange Level ![]() ![]() Joined: 27 Mar 2011 Location: Shandon, CA Points: 2175 |
It is a Wisconsin, the air cooling shroud is gone and that is where the data plate is. Almost indestructible, as proven this has been run with no cooling, they can take almost anything but no oil.
Edited by Tad Wicks - 16 Aug 2021 at 10:13am |
