ID Center
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Topic: ID Center
    Posted: 10 Feb 2012 at 1:18pm
Can anyone identify this center in the black and white pic? The color pic is of Avery Tractor centers and looks pretty close to the B&W but hard to tell.
Edited by mdtractormechanic - 11 Feb 2012 at 11:03am
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 11:04am
Any ideas?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 11:06am
Look identical to me.
ALLIS EXPRESS!
This year:
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 11:59am
The tractor in the picture sure looks like  a C by the fender shape and the air cleaner and carb location.  I just looked in my B C parts book, it does not list a stamped steel wheel center for a B or a C, could be a small Farmall or like you said and Avery.    Also Cs only used 5 wheel bolts per side. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 12:39pm
The B&W pic has a round look to the outside but the ones on the pallet don't look round. ??? Other than that, they look very similar.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 12:51pm
ford centers?
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 1:29pm
Farmalls used this type of  centers on there B and BN tractors. Allis also used them on D10 non spin out. You can use this center on a CA with loop style rim. In the picture the give away is the square type loop on the rim early Farmalls had these. You can put B/C rear steel on a CA with these centers also.
hAVE A GOOD ONE bill p
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 4:24pm
Thanks All, I see that the Avery and the Farmall B's are identical. The B&W pic is of an AC prototype that I am thinking of duplicating.  Made mostly of B parts, the engineering of a copy should prove to be interesting.
