IB generator diagnosis update |
Freewheeling
Joined: 05 Nov 2017 Location: Wisconsin Points: 170 |
Topic: IB generator diagnosis updatePosted: 18 Sep 2023 at 12:19pm |
A couple weeks back I posted on issues with my IB charging system. Here's the histroy and what I've found so far.
I disassembled
and replaced the brushes, bushing bearing, & end cap because 3rd
brush post was bent. I coated the wire from the field coil where it had been
rubbing on the commutator. Reassembled
the generator and fired up the tractor.
At half-throttle the amp meter went all the way over to full charge of
20 amps. Moving the 3rd brush
didn’t make any difference. Thought
perhaps it was the amp gauge so I opened the switch box. I removed the old gauge but discovered that
the new gauge I had would not fit in the switch box cover so I reassembled with
the old gauge. While attempting to close the switch box the box rubbed through
a wire in the harness and shorted out resulting in sparks and smoke. I
disconnected the battery, taped up the wire, and reassembled the box. I restarted the tractor and the amp gauge
showed 20 amps discharge and the cutout didn’t close. I removed the generator and
disassembled. Tested the system with a
multimeter set at 200 ohms. I then
reassembled and tested again. Results: 3rd brush and F terminal –
Disassembled 2.2-2.3 ohms Assembled – Same F terminal to ground (case) –
Disassembled – Open Loop (OL) Assembled
3.3 ohms 3rd brush to ground (case)
– Assembled - 0 .3 ohms Main brush (not the grnd) to ground
(case) – 0.3 ohms “A” terminal to ground (case) – 0.3
ohms There is no evidence of any damage or
deterioration in the circuitry within the generator or the wiring harness other
than at the entry to the switch box where I taped it up. There is continuity in the wire from the
3-way “S” terminal to the headlights and taillight. There is also continuity in the wire from the
generator Field terminal to the 3-way and in the wire from the “B” terminal on
the cutout to the (-) side of the amp gauge. The fuse is good. The resistor
reads 3.3 ohms. The switch box has a clean, bright connection to the steering
post. Battery reads 6.3 volts. I opened the switch box and removed the tape from the wiring harness. The shorted wire is the one that connects the cutout battery terminal to the amp gauge (-). This might explain why both the cutout quit working and the gauge shows discharge after the short. ??? Finally, with the switch box still open I ran a jumper from the base of the 3-way switch to the bolt that attaches the box to the steering post. With 3-way switch all the way in and one probe on the end of the “F” terminal wire and the other on the battery + post I got 3.8 ohms. With the switch both halfway and all the way out I got 0.1 ohms. If anyone sees something that could cause the problem please let me know. I’m on my way to a electrical repair
shop to get a new cutout and have the generator bench tested. Thanks y'all!!
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5188 |
Posted: 19 Sep 2023 at 7:12am |
Just a suggestion, but instead of getting a new cutout, think about replacing the cutout with a voltage regulator and replacing the headlight switch with a regular push-pull switch.
I have converted a few over the years and I like the voltage regulators much better. No more overcharging battery.
Joined: 11 Sep 2009 Location: illinois Points: 90823 |
Posted: 19 Sep 2023 at 8:14am |
the short story is there is not a good way to get the generator to put out 20 amps, without GROUNDING the "F" terminal.... that can be internal, the wire to the switch, or the switch itself............. I dont see any other way to do it... but have no explaination of the resistance numbers you measure.
Les Kerf
Posted: 19 Sep 2023 at 3:40pm |
Yup, I'm with you on this Steve, which is why on his previous thread I had suggested that he test the generator by bypassing the stock wiring; he is now going to pay someone to do this for him in their shop. Probably a good plan.
Freewheeling
Thanks(1)
Posted: 22 Sep 2023 at 6:55am |
The shop checked the generator and got a 5
amp discharge so I'm replacing the ammeter. The shop will
get into the genny next week.
Since everything else seems to be OK and the
only thing I didn't check was the armature, I'm thinking that's the
cause of the malfunction.
As for the cutout, I know a regulator is a better option and use
them on my work tractors but I want to restore the IB to as original as
possible. She's going to be a trailer queen. |
Les Kerf
Posted: 22 Sep 2023 at 9:55am |
Thanks for the update, let us know what they find in the generator.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 22 Sep 2023 at 5:47pm |
It probably needs an Arm. It's a common thing. That's why I automatically change them out anytime I rebuild a unit for a customer. I don't get involved with messin' around with a 60+ year old Arm even if it shows good. It's like using a old pair of laces on a new pair of shoes...... Steve@B&B
Freewheeling
Posted: 24 Sep 2023 at 8:02am |
Steve -What's the price of a new armature? Are the truly new or reman?
Steve in NJ
Posted: 24 Sep 2023 at 8:01pm |
For my rebuilds I have my rewinder whittle me a fresh arm so it's like new when done. I have him wind them a little "tighter" as well when he does them, especially the arms for the Starter motors. Gives em' a little more torque especially on the 6V units. ![]() Steve@B&B
Freewheeling
Posted: 24 Sep 2023 at 10:40pm |
Price?
Steve in NJ
Posted: 25 Sep 2023 at 4:54am |
If it's a 6V Gennie, they usually run around $250-$275. to rebuild from me for the cutout version. If you want to move to a VR and get away from the charging side of the light switch it usually runs around $325. which includes the wiring from the Gennie to the VR. Both are dialed in on my 881 machine, so all components are mated to work together. I don't sell components for the Gennie's or Starter motors. To many variables inside these old units. Lots of times the books are incorrect anyway. I only build complete units....
Freewheeling
Posted: 04 Oct 2023 at 7:55am |
I picked up the generator from the repair shop. The tech who worked on it found nothing wrong with the components (fields, armature, brushes, etc.) However he said the third brush was set close to the main brush and the genny was putting out 45 amps. With the 3rd brush set all the way back it still puts out 14 amps. I questioned whether that seemed normal. Based upon what I've been told there should only be 5-7 amps output when fully grounded. He was a younger guy and seemed to know what he was talking about. There is an old fossil like me in the shop so if this doesn't make sense I'll ask him to look at it.
By the way, I did find an original Duetz-Allis 20 amp ammeter made in the USA.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 04 Oct 2023 at 8:04am |
I'd expect 15 amps when 'fully grounded', 5-8ish when resistor is in series,depending on resistor value. Old skool idea was gennys don't put a lot out, BUT run all day long, so batteries get fully recharged. If you only do 'short run' operations better to swap over to alternator or put battery charger on tractor every day.
Posted: 04 Oct 2023 at 8:05am |
14 amps fully ground is on the HIGH SIDE... But probably not a big deal as you normally dont run fully grounded.... You can also change the RESISTOR value a little bit if you dont like the charging amps you get running thru it.
Freewheeling
Posted: 04 Oct 2023 at 8:43am |
OK. Great. Info I had was 3 amps through the resistor to the battery (switch all the way in) and 5-7 in the second & third positions. I suppose there is a lot of variability in these old systems and if you use some common sense it's not a big deal. I was surprised to learn that a 6 volt genny could put out 45 amps.
The shop changed the bearing which I had provided, cleaned up the commutator, reset the 3rd brush, and tested another armature I had. Charged me $50. Very willing to answer any questions. Fondy Auto Electric in Fond du Lac, Wis.
Freewheeling
Posted: 04 Oct 2023 at 8:52am |
Original resistors were 3 amp and the one I installed is 3.3 amp. So I'll be putting 10+ amps to the battery with the switch all the way in. It's a bit high but since she won't see a lot of run hours I don't think it will matter.
Posted: 04 Oct 2023 at 9:10am |
You can always add another 2- 3 OHM resistor in the "F" wire to the switch at a later date if needed... It does not need to be on the switch...
Edited by steve(ill) - 04 Oct 2023 at 9:10am |
Freewheeling
Thanks(1)
Posted: 01 Nov 2023 at 2:42pm |
Eueka! My IB charging system is finally fixed. Beside the genny end plate and brushes I had to replace the ammeter, generator mounting bracket, and fan belt. I was able to find a NOS ammeter and slotted mounting bracket. Apparently the old ammeter was defective which resulted in the high discharge reading. I have a new wiring harness coming from B&B which should bring the entire system up to snuff. I now actually understand how these old electrical systems work. Thanks for all your input.
Les Kerf
Posted: 02 Nov 2023 at 11:46am |
Thanks for the update, it is so nice to know what actually solved the problem; far too many of these threads end with no resolution.
