IB Detroit Harvester Mower Issue
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Topic: IB Detroit Harvester Mower Issue
    Posted: 04 Aug 2012 at 10:07pm
hey guys Im putting all new sickles in my mower and I used the new style bolts instead of rivets inside the bar. The guards I have are to small with the new bolts. is there another style guard i could put in there that would clear the bolt and nut on the sickle bar. dad thought maybe a john deere guard would give enough clearence. any suggestions?? thanks blake
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 9:28am
I remember Dad doing this on one of the haybines sickle bars. We had to put all new hold downs in it to clear the bolts. The new ones had a taller arch over the sickle bar to allow the bolt ends to clear. There wasn't a problem with the guards. Haybine was a NH and they stocked the taller hold downs for those wanting to use bolts instead of rivets for sickle sections.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 7:49pm
When I converted my 82S over to bolts some of the original holddowns would work with a "wee" bit of grinding on the nuts.
Those where the knifehead are would not work at all.  I was able to pick up some "high-clearance" holddowns from tractor supply.
