i-600 shuttle shift
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: i-600 shuttle shift
    Posted: 28 Nov 2010 at 9:00pm
my shuttle shift is starting to slip not much engageing to the hand lever left can you shim up or remove some shims like the hand clutch on the old wd's and the 45's on the left hand side acess cover of the i-600?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 7:36am
yES, SHUTTLE CLUTCH IS THE SAME AS TRACTORS WITH HI/LOW RANGE. THE ONLY DIFFERENCE IS THE SHUTTKE CLUTCH HAS ANOTHER GEAR INSTALLED TO MAKE LOW REVERSE
1968 D15D,1962 D19D
