I-600 ring gear with forks
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: I-600 ring gear with forks
    Posted: 26 Jun 2013 at 6:12pm
Anyone change the ring gear in an I-600 with forks on the front.
Just finished taking the starter off and the drive plus casting on the end of the starter
was  broken and some small pieces of the casting had fallen down.
Procedure for spliting to repair. thanks
Fred
Edited by WD45 - 26 Jun 2013 at 8:20pm
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2013 at 7:51pm
I would think the ring gear would be the same as a D15 tractor.  I bet that a ring gear to a 149 or 160 gas engine would work as well.
Procedure should be pretty straight forward.  Pull cowl, radiator, stabilize tranny and torque tube.
Secure engine crane and attach engine lift to head, disconnect four engine bellhousing bolts and slide engine back.
Flywheel will be exposed.  Order new ringgear heat and install let cool.  Reverse process.  An service manual would also be helpful.
Last please make sure you work safely.   Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2013 at 8:45am
WD 45 sent you a PM.  Let me know if you need additional information.
Long Live AC !!!
This page was generated in 0.445 seconds.
