I600 backhoe
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: I600 backhoe
    Posted: 26 Sep 2025 at 4:25am
Guys I’m having trouble with the steering on my I600. I’m removing the steering cylinder for a rebuild. If that gets the steering working I’d like to remove the hoe. What do I do with the hoses that run the hoe? I believe there are 3.
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 4:35am
u going to devoice the hoe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 5:00am
Probably. The rotary swing motor is leaking. A couple other cylinders are leaking. Needs a few hoses. This hoe is big and makes the tractor hard to maneuver here in the hills. I could get a lot more use out of the tractor without it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 1:35pm
here is the general idea... I guess your question is do the supply and return hoses connect together to make a LOOP... or do you leave them seperate to DEAD HEAD them..
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:01am
 I had to remove the backhoe of my D14 for repairs to the rotary swing cylinder,,Dang, That was a BFJ,,,,!!! I did not loop the hoses,,,,,,?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 20 minutes ago at 4:32am
What did you do with the hoses Joe?
