I600 backhoe |
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9663 |
![]() ![]() ![]() ![]() ![]() Posted: 16 hours 1 minutes ago at 4:25am |
Guys I’m having trouble with the steering on my I600. I’m removing the steering cylinder for a rebuild. If that gets the steering working I’d like to remove the hoe. What do I do with the hoses that run the hoe? I believe there are 3.
fjdrill ![]() Silver Level Access ![]() Joined: 13 May 2012 Location: Alabama Points: 385 |
u going to devoice the hoe?
Probably. The rotary swing motor is leaking. A couple other cylinders are leaking. Needs a few hoses. This hoe is big and makes the tractor hard to maneuver here in the hills. I could get a lot more use out of the tractor without it.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88080 |
here is the general idea... I guess your question is do the supply and return hoses connect together to make a LOOP... or do you leave them seperate to DEAD HEAD them..
